what turbo will suit me best? d16y8 autox, street, drag, daily, 300+whp
Old Jan 9, 2004 | 09:14 PM
Itz Darave's Avatar
Default what turbo will suit me best? d16y8 autox, street, drag, daily, 300+whp
eagle rods, srp pistons, crower stage 2 cams, pnp etc...
9:1 compression or 10.2 depends... high compression lower boost needed... right?
i want 300 whp at least... what turbo can spool fast enough for auto x... and still make 300whp? if not i think id have to settle with 250whp with turbo and 50 shot of n2o... or what ever... stock block too and some FINE tuning just like your sister
Old Jan 10, 2004 | 08:55 AM
Itz Darave's Avatar
bump 1
Old Jan 10, 2004 | 09:11 AM
uranazo's Avatar
BUMP!!! id also like to know
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: what turbo will suit me best? d16y8 autox, street, drag, daily, 300+whp (Laosfu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laosfu &raquo;</TD></TR><TR><TD CLASS="quote">eagle rods, srp pistons, crower stage 2 cams, pnp etc...
i want 300 whp at least... what turbo can spool fast enough for auto x... and still make 300whp? if not i think id have to settle with 250whp with turbo and 50 shot of n2o... or what ever... stock block too and some FINE tuning just like your sister</TD></TR></TABLE>
Sounds like you're dreaming to me.
You'd be okay with "settling" for 250whp? Have you ever RIDDEN in a 250whp FWD Honda? PLENTY of power for the street, and plenty of guys on this board can attest to that.
I'm not even going to throw out recommendations yet. You've got a lot of reading to do on this forum.
Old Jan 10, 2004 | 09:30 AM
nikolai.'s Avatar
you wont be able to autox with a nitrous tank in your car. you'd have to remove it for each event.
Old Jan 10, 2004 | 09:37 AM
notfastenough's Avatar
Probably would settle for 250 hp with that 50 shot b/c it will always give 50 hp more.
Old Jan 10, 2004 | 09:40 AM
Burke's Avatar
Banned
Default Re: (NB)
.48 trim t3/to4b. leaves you lots of room. prolly wont spool till like 4-4.5k on a SOHC, but will still give you lots of top end. i was running 12's with that same turbo on an ls. they are dirt cheap too
Old Jan 10, 2004 | 05:29 PM
Itz Darave's Avatar
well of course i know i cant use n2o in autoX ing
Old Jan 10, 2004 | 05:54 PM
streetlvlhatch's Avatar
Default Re: (Laosfu)
I think your hp goals and drivability dont go well together. a 300 whp d-series is a pretty rare occurance. it needs the right combinations and a lot of money. There are only a few with those numbers on here.
Bailhatch's Avatar
I would go higher compression and use a super 60 T3. You won't hit your HP goal but it will be a pretty fast street car with over 225whp i would guess.
I had a T25 on my Z6 and it was incredible for auto-x. It would start pulling hard before 3000 and continue to about 5500 then it eased off up top. I got great times because there was no downshifting to 1st for hairpins. The midrage torque and instant response was ideal. I was probably making about 150-160whp but in a 2000 lb hatch with the SOHC TQ I was keeping up with evo8s, wrxs, 911s (with an awesome driver). Now i'm going to try and make over 200 with a .63turbine and .42comp T3 that cost me $25!
My buddy has a t3/t4 (57trim with stg3 turbine)on a b18b but he won't auto-x with me anymore because it starts to pull at the end of the straights and is doggy out of boost. you'll hate it if you go too big, unless AX is seccondery to street power...
Old Jan 10, 2004 | 06:23 PM
pissedoffsol's Avatar
Default Re: (streetlvlhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetlvlhatch &raquo;</TD></TR><TR><TD CLASS="quote">I think your hp goals and drivability dont go well together. a 300 whp d-series is a pretty rare occurance. it needs the right combinations and a lot of money. There are only a few with those numbers on here.</TD></TR></TABLE>
i agree. 300 whp d-series drag cars are rare... and you want a daily driven one. you're going to be pushing it wicked hard dude. i'd seriosulty re-consider your plan if this is your only vehicle.
Old Jan 10, 2004 | 10:03 PM
Itz Darave's Avatar
300whp rare occurance yea... but with some fine tuning it should happen...
im leaning towards 10.2 compression srp pistons and eagle rods and fully built head... and maybe a 16g turbo or a super60 t3
Old Jan 11, 2004 | 02:30 PM
Bailhatch's Avatar
can a super 60 put down 300? don't they make about 320crank?
ChrisYuki
Aug 16, 2015 08:19 PM
CRXherbie91
May 25, 2008 08:23 AM
nah22accord
May 21, 2006 12:17 AM
nah22accord
Feb 2, 2006 07:57 PM
ludeNstein
Jul 2, 2002 12:13 PM
