Clutch master cylinder going out?
Old Jan 9, 2004 | 03:56 PM
K20DC2R's Avatar
Default Clutch master cylinder going out?
has anyone else have had their clutch master cylinder go out? i think mine went out on my itr. just wondering if anyone else has experinced the same problem..
Old Jan 9, 2004 | 04:13 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Clutch master cylinder going out? (VtecWhore)
I haven't, but what makes you think it's the MC thats going out?
Old Jan 9, 2004 | 04:25 PM
Kicker773's Avatar
Default Re: Clutch master cylinder going out? (Emerika)
if it's making noises .. that probably just the spring.. but i actually replaced mine since i found a good deal for a new one.. that freakn noise when i press the clutch wasjust getting annoying..
Old Jan 9, 2004 | 04:28 PM
revhigh89's Avatar
how do i replace that? i got one but i dunno how to replace it? imtoo lazy to search
Old Jan 9, 2004 | 04:34 PM
Smitdog's Avatar
Default Re: Clutch master cylinder going out? (evilryu530)
My MC is bad, if you look under the dash see if the push-rod area is leaking and you should also have un-even clutch engagement.
New MC and Slave are not expensive at all and are a ease to replace.
Old Jan 9, 2004 | 04:36 PM
Kicker773's Avatar
Default Re: Clutch master cylinder going out? (Smitdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smitdog &raquo;</TD></TR><TR><TD CLASS="quote">My MC is bad, if you look under the dash see if the push-rod area is leaking and you should also have un-even clutch engagement.
New MC and Slave are not expensive at all and are a ease to replace. </TD></TR></TABLE> yup you just have to look for places that are sellin them.. just dont get ripped by the dealer.. =T
Old Jan 9, 2004 | 04:47 PM
hybridzOr's Avatar
Default Re: Clutch master cylinder going out? (Kicker773)
links?
Old Jan 9, 2004 | 06:10 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Clutch master cylinder going out? (HybridRacer)
back to the original post.....why do you think the MC is bad?
Old Jan 9, 2004 | 06:40 PM
cheezthis's Avatar
You'll know if it's going back...one thing to check for is leaks on it. If so, it's not hard to change.
Also, check you slave cylinder. But...as asked already, why do you think it's bad? What's going wrong w/the car?
Old Jan 11, 2004 | 09:20 PM
2camsaam's Avatar
Can someone elaborate on what he means by uneven engagement? I believe I am having the same problem, however, I already replaced the MC on Saturday, I will be installing a new slave cylinder tomorrow to see if this fixes the probl.
Old Jan 12, 2004 | 11:55 AM
The Kernel's Avatar
Default Re: Clutch master cylinder going out? (2camsaam)
My master cylinder squeaks constantly now. Very annoying. I'll have to check for leaks. Hopefully acura will fix this for me whenever I have time to schedule an appointment.
ZenDynasty
24
Jun 1, 2008 07:56 PM
93H22Vtec
Jan 20, 2007 08:41 AM
FuNkDrSpOt
Oct 10, 2006 09:48 PM
TurblowR
Mar 28, 2005 06:26 PM
GoLowDrew
Jul 15, 2001 05:41 AM
