95 Integra will not start
Old Jan 9, 2004 | 03:17 PM
gsr2jdm's Avatar
Default 95 Integra will not start
Cranks but no go....
looks like ecu is not getting any power, check realy and it does click. I am gettin fuel pressure because i loosened banjo bolt on fuel filter and fuel misted out. Afc does not turn on but when I put battery charger on the battery and tried again afc flickered and car stumbled to almost idle then just kept cranking..
Could this be caused by a dead battery....
Old Jan 9, 2004 | 05:42 PM
Bimmer99's Avatar
Default Re: 95 Integra will not start (gsr2jdm)
do you still have the original battery ? if so prolly need to replace it . if it's more than that try taking it to a dealer Muller's Woodfield acura is a great one . i used to work there and i believe they have one of the cheapest labor rates out of acura dealers.
Old Jan 9, 2004 | 08:21 PM
gsr2jdm's Avatar
**** i know its gotta be something that i'm looking right at like a bumb fuse or someshit....
plus my car has no windshield
Old Jan 9, 2004 | 08:31 PM
rtype11's Avatar
Default Re: 95 Integra will not start (Bimmer99)
i bought my teg there in 98 right in Schaumburg Il, used to race it up and down higgins and golf links road.
Old Jan 9, 2004 | 11:06 PM
cheezthis's Avatar
Default Re: 95 Integra will not start (rtype11)
Check the ECU fuse first...if not, maybe I can help you out if I actually I find some free time. I live in the city. And yes, Muller's Woodfield Acura is a pretty good place. I like them for service, and sometimes I go to McGrath for parts. They're both good places. Also, you could call Benson over at Garage Kwai...but for something like this, I don't think it's necessary. Check your fuses and connections, definitely sounds electrical. If it doesn't work out, send me a PM, and I'll see what I can do.
Old Jan 10, 2004 | 07:46 AM
START's Avatar
Make sure that your timing belt did not get cut by any chance. Check your fuses and relays. Another suggestion, buy a P28 and see if that starts the car. What is the last thing you did to the car before it started acting up?
Old Jan 10, 2004 | 07:48 AM
START's Avatar
Oh yeah, are you getting any spark? The main two things that usually prevents the car from starting is fuel and spark. Check and see if your distributor is working? If you have an aftermarket ignition, take off the distributor cap and make sure none of the wires in side are touching.
Old Jan 11, 2004 | 07:16 PM
gsr2jdm's Avatar
alright i got the car to start thanks guys i guess the headgasket was on reverse so i replaced it and now the car runs...
thanks for your help
Old Jan 11, 2004 | 11:59 PM
rtype11's Avatar
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr2jdm &raquo;</TD></TR><TR><TD CLASS="quote">alright i got the car to start thanks guys i guess the headgasket was on reverse so i replaced it and now the car runs...
thanks for your help</TD></TR></TABLE>
sorry man i still havent figured out whether you were fu**ing with us or for real, the headgasket and no windsield etc.. let me know if we've just been played, cause I am not sure.
Old Jan 12, 2004 | 08:23 AM
gsr2jdm's Avatar
na man the car is in my garage, it just needs a little love thats all....
Jaxis
Oct 1, 2014 02:09 PM
hondagurl00
May 9, 2013 04:52 PM
Singha83
Nov 26, 2012 05:34 AM
chrisnova
Mar 7, 2007 07:45 PM
braypunt
22
Sep 11, 2005 09:10 AM
