Nitrous Type-R dyno plots inside
Old Jan 9, 2004 | 03:04 PM
Austin's Avatar
Default Nitrous Type-R dyno plots inside
Alright guys…Nitrous Type-R, 2000 Type-R
This is not my car.
AEM CAI
NOS direct port, 100 shot
Jacobs Nitrous Mastermind
MSD ignition system
Colder plugs
Stock header
Stock cat
Stock exhaust
The nitrous system has been tuned to gradually add in the nitrous oxide, starting with 50%, and as the RPMs increase the amount of nitrous also increases, there is an ignition retard in place, but I couldn’t give you the exact specifications.
Here’s the plot…
Full size, cut and paste into your browser window:
http://www.imagestation.com/pi...g.jpg
Old Jan 9, 2004 | 03:08 PM
vtec.dc2's Avatar
Default Re: Nitrous Type-R dyno plots inside (Austin)
looks like fun..
Old Jan 9, 2004 | 03:18 PM
MAD ITR 55's Avatar
Pretty nice numbers,but nitrous is not for my R.
Old Jan 9, 2004 | 03:20 PM
Misfit's Avatar
Default Re: (MAD ITR 55)
IF you do it right its not that bad. I was thinking doing the same thing with the Nitrous Mastermind.
Old Jan 9, 2004 | 03:24 PM
vtec.dc2's Avatar
looking at his setup and for the money he spend this doesn't sound bad at all.. only set back is nawwsss refills - if you gonna nawwwss often, then might as well get turdblow.
torque per hp is very good.. torque itself is good, hp is falling of quick, but then its all stock.. thats a sleeper setup..
Old Jan 9, 2004 | 03:32 PM
Austin's Avatar
Default Re: (vtec.dc2)
The stock ECU causes the car to run unbelievably rich, if there was a Hondata, header, high flow cat, and exhaust...
Old Jan 9, 2004 | 05:42 PM
B2FiNiTY's Avatar
So the mastermind system allows the nitrous to slowly be added?
Impressive numbers. Must be a sleeper.
Old Jan 9, 2004 | 05:52 PM
JDMSI's Avatar
Default Re: Nitrous Type-R dyno plots inside (B2FiNiTY)
SVP has a pritty fast NOS type R check it out http://www.onlineshowoff.com/i...ecitr
Old Jan 9, 2004 | 06:15 PM
JjuuN R's Avatar
awsome
Old Jan 9, 2004 | 06:17 PM
98itR484's Avatar
Default Re: Nitrous Type-R dyno plots inside (JDMSI)
blahhhhhhh bottles of for babies
I wonder how that would be on the track (NOT DRAG) I wonder how the mastermind would work on downshifts/accel anyone know?? It would probably be very tricky to drive. (not that i want to go nawwwwwsss or anything)
Old Jan 9, 2004 | 06:20 PM
JjuuN R's Avatar
Default Re: Nitrous Type-R dyno plots inside (98itR484)
most of the time no2 is controlled by the user
so i wouldn't see it being difficult at all if used on the track
Old Jan 9, 2004 | 07:00 PM
obd2gsr's Avatar
That's pretty sweet. He's really going to be putting the hurt on if you're not aware of that setup!
Old Jan 10, 2004 | 04:13 AM
TurboR1391's Avatar
Default Re: Nitrous Type-R dyno plots inside (obd2gsr)
Very nice numbers and a simple setup too.
Old Jan 10, 2004 | 06:17 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Nitrous Type-R dyno plots inside (TurboR1391)
Nitrous ownz
Old Jan 10, 2004 | 06:21 AM
B18CXr's Avatar
Default Re: Nitrous Type-R dyno plots inside (RealTypeR)
Nitrous ownz
your old short block, which is still on my engine stand in the shop
Old Jan 10, 2004 | 06:55 AM
Default Re: Nitrous Type-R dyno plots inside (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote"> Nitrous ownz
your old short block, which is still on my engine stand in the shop </TD></TR></TABLE>
**** yes
Old Mar 7, 2004 | 05:05 AM
ITR-Spoon's Avatar
damn nice numbers, i was thinkin about going nitrous .....
Old Mar 7, 2004 | 06:41 AM
Young_R's Avatar
Default Re: Nitrous Type-R dyno plots inside (PY-ITR-#977)
WAAAH that pretty high numbers. very nice.
Old Mar 7, 2004 | 06:57 AM
machgo5go's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAD ITR 55 &raquo;</TD></TR><TR><TD CLASS="quote">Pretty nice numbers,but nitrous is not for my R.</TD></TR></TABLE>
Kaboom factor!
Old Mar 7, 2004 | 07:13 AM
vtec.dc2's Avatar
Default Re: (machgo5go)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machgo5go &raquo;</TD></TR><TR><TD CLASS="quote">
Kaboom factor!</TD></TR></TABLE>
only when you don't know what you're doing.. or motor has shown is age..
Old Mar 7, 2004 | 07:18 AM
ITR764's Avatar
that rimze y0!!!!
Old Mar 7, 2004 | 09:44 AM
Black R's Avatar
25 Year Member
.....how much for dat?
Old Mar 7, 2004 | 09:58 AM
c5_el's Avatar
those are some sick numbers
ImportCarPartsPlus
Dec 25, 2008 01:02 PM
Austin
Jan 10, 2004 08:31 AM
