what should your compression be after a comression test on lowered compression motors?
Old Jan 9, 2004 | 12:01 PM
Nextelbuddy's Avatar
Default what should your compression be after a comression test on lowered compression motors?
just curious, if u build your motor with lower compression pistons such as 9:1 and you perform a compression test, what shoudl the nubers be around accross the board?
i had 210 210 210 210 on stock pistons and rods, just curius before i start getti into it thats all.
Old Jan 9, 2004 | 12:31 PM
ek9turbo's Avatar
Default Re: what should your compression be after a comression test on lowered compression motors? (nextelbu
i have 8.9:1 cr
my compression test showed 175psi in all cylinders
Old Jan 9, 2004 | 12:42 PM
anyone else?
i want to now so that when i do a compression test i will know what numbersd are good and what are bad that will help me figure out if my rings are seated properly or not.
Old Jan 9, 2004 | 12:47 PM
VTC_CiViC's Avatar
More important than specific numbers is equal compression in all 4 cylinders.
FWIW, on a 9.6:1 CR Civic, I was getting 190-195psi accoss the board.
Old Jan 9, 2004 | 12:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">More important than specific numbers is equal compression in all 4 cylinders.
FWIW, on a 9.6:1 CR Civic, I was getting 190-195psi accoss the board.</TD></TR></TABLE>
yea i understand that part about the consistancy of the numbers to each other.
but i just wanted to know how much from 210 psi i have now will i have with 9:1 comression?
Old Jan 9, 2004 | 03:12 PM
pip9's Avatar
I just did a compression check on my car, 175-180 across all 4 cylinders. I have 9.0:1 compression pistons
Old Jan 9, 2004 | 03:55 PM
D@nnY's Avatar
190 ..9.1 in gsr 84mm
Old Jan 9, 2004 | 06:18 PM
b00stedbyFastrax's Avatar
Default Re: (GSRT37)
175 across on 8.0:1 CR.
negusjuda
Apr 3, 2013 02:33 PM
self_made
Jun 19, 2005 12:36 PM
Mr.Integra
Apr 22, 2004 07:55 PM
builtprelude
Jan 22, 2004 10:49 PM
