Key stuck in ignition
Old Jan 9, 2004 | 09:48 AM
bd1504's Avatar
Default Key stuck in ignition
I had to replace the AT Control unit in my 1991 Honda Accord EX. The AT control unit shares a mounting bracket with the ECU which meant I had to disconnect both. I replaced the AT control unit and then re-installed it plus the ECU. It started up fine but when I went to shut it off I could not remove the key. I tried turning the steering wheel both ways to make sure it wasn't keeping the key from being removed. Does anyone have an idea to why the key can't be removed ?
Old Jan 9, 2004 | 09:55 AM
JimBlake's Avatar
Default Re: Key stuck in ignition (bd1504)
Check your shift-lever interlock. It's not supposed to let you take the key out unless the gearshift lever is in Park.
1) Maybe the contacts in the shift lever aren't closing. Adjustment? Can you get your key out by pushing the shift lever farther forward?
2) Open circuit between those contacts & the solenoid that holds or releases your key from the lock cylinder.
Old Jan 9, 2004 | 12:39 PM
.bagged's Avatar
Default Re: Key stuck in ignition (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Check your shift-lever interlock. It's not supposed to let you take the key out unless the gearshift lever is in Park.
i agree it sound electrical. a safety relay of some sort..
Old Jan 9, 2004 | 01:23 PM
.bagged's Avatar
Default Re: Key stuck in ignition (bagged93accord)
Worst comes to last search Chip Foose. he has designed a new ignition that works off a key card. Like a credit card and when you stick it in the car starts remove and it turns off
Old Jan 15, 2004 | 07:43 PM
Riceburner247's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord &raquo;</TD></TR><TR><TD CLASS="quote">Worst comes to last search Chip Foose. he has designed a new ignition that works off a key card. Like a credit card and when you stick it in the car starts remove and it turns off </TD></TR></TABLE>
don't listen to him, he's not one of us.
I don't pay rent, either.
.......hahahaha, I think I've been owned, but I'm not sure.
Modified by riceburner247 at 8:57 PM 1/15/2004
Old Jan 15, 2004 | 07:45 PM
.bagged's Avatar
Default Re: Key stuck in ignition (riceburner247)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 &raquo;</TD></TR><TR><TD CLASS="quote">
don't listen to him, he's not one of us.</TD></TR></TABLE>
You sleep on my couch..
but you do the laundry and dishes everyday sweetie..
Old Jan 15, 2004 | 07:51 PM
The_Todd's Avatar
Farts in the shower
but you do the laundry and dishes everyday sweetie..</TD></TR></TABLE>
OWNED
Old Jan 15, 2004 | 07:55 PM
iam7head's Avatar
Default Re: Key stuck in ignition (VRDrvr)
you need to have the shift cable adjusted, try yank the shifter stick, I am 99percent sure it's the buttem on your shifter
take apart the cover and you'll see a meaty size cable and a adjusting nuts
Old Jan 15, 2004 | 07:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Check your shift-lever interlock. It's not supposed to let you take the key out unless the gearshift lever is in Park.</TD></TR></TABLE>
Sounds good to me.
minguswooten
Honda Civic (2001 - 2005)
Oct 8, 2021 07:46 AM
mucjbpe
May 8, 2014 06:38 PM
mickyT
Nov 10, 2007 08:46 PM
JohnnyA
Nov 19, 2004 11:59 AM
sLo B18b
Jul 5, 2004 12:17 PM
