Gathering parts for a LS/VTEC Build, let me know what you think of my set up so far
Old Jan 9, 2004 | 08:49 AM
Altered's Avatar
Default Gathering parts for a LS/VTEC Build, let me know what you think of my set up so far
The motor
95 B18B Block:
Wiseco 10.2:1 (w/ B16 Head) 81.5mm Pistons
Crower Econo Billets
Race Engineering Block Guard
ACL Bearings
ITR Oil Pump
Pro Drive Oil Pump Gear
B16A Head:
Portflow Headwork
ITR Outer V-Springs, Portflow inner V-Springs
Supertech Valves
2001 ITR Cams
Venom IM
RC 7xxcc Injectors (Undecided)
STR TB
STR Fuel Rail
Hondata S200B Tuned by AEBS
Turbo Set Up:
Custom Tubular Manifold (Similar to full Race)
Precision SC61
Tial 38mm WG
Custom DP
Custom 28 x 10 x 3.0 IC core
Apex BOV
Custom IC Piping (Still searching for a pre-fab'd kit)
B16 Trans:
1st. 3.077 (ATS)
2nd 1.900 (GSR)
3rd 1.458 (B16)
4th 1.458 (B16)
5th 0.787 (GSR)
FD 4.4 (B16)
Quaife LSD
DSS Axles
This is for a car that will be daily driven at no more than 10-12 PSI and will from time to time see the strip at no more than 16 PSI on race gas.
Criticism, Comments and Suggestions welcome
Old Jan 9, 2004 | 08:55 AM
rondigs's Avatar
Default Re: Gathering parts for a LS/VTEC Build, let me know what you think of my set up so far (Altered)
If your putting all that money into a build up, why such low boost?
Also, you may what to think about putting a girdle on the ls bottom end. Its not absolutely neccessay, just insurance. You may also what to think about a more economical intake manifold. Like the JG edelbrock. They can be had (used) for pretty cheap. I got mine for $200.
Old Jan 9, 2004 | 09:10 AM
Altered's Avatar
Default Re: Gathering parts for a LS/VTEC Build, let me know what you think of my set up so far (rondigs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rondigs &raquo;</TD></TR><TR><TD CLASS="quote">If your putting all that money into a build up, why such low boost?</TD></TR></TABLE>
Its my daily driven street car, The Build is just for insurance and reliability with the turbo. I have an all motor hatch for the track so I dont really feel the need to go all out with this car, I just wanted a quick street car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Also, you may what to think about putting a girdle on the ls bottom end. Its not absolutely neccessay, just insurance</TD></TR></TABLE>
I put a little though into a girdle but in the end I felt it was something I didnt really need. Ive seen several LS VTEC's rev to 10+ with out a girdle, my old LS/VTEC rev'd to 9K almost daily with out a girdle and had no problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">You may also what to think about a more economical intake manifold. Like the JG edelbrock. They can be had (used) for pretty cheap. I got mine for $200</TD></TR></TABLE>
I already had the IM, didnt pay anything for it
Old Jan 9, 2004 | 10:07 AM
Doodoo's Avatar
Man I tell you my situation, I hope it helps.
I spent money building a LS head like you have and I regret it. My next head will be dual valve springs and a clean up job. I found the headwork and the valves and the TB all a waste. I could have put that money into something else.
I built my block the same way you want to minus the Pro-Drive gear and rods. I regret that too. Consider sleeving even if it is out of your budget at this time.
Because of these regrets I have not driven my baby since June of last year. Impatience and the inproper parts cost me big time.
Good luck
Old Jan 9, 2004 | 11:07 AM
Altered's Avatar
Default Re: Gathering parts for a LS/VTEC Build, let me know what you think of my set up so far (Doodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doodoo &raquo;</TD></TR><TR><TD CLASS="quote">I spent money building a LS head like you have and I regret it</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Altered &raquo;</TD></TR><TR><TD CLASS="quote">B16A Head:
Portflow Headwork
Supertech Valves
2001 ITR Cams
Venom IM
STR TB
STR Fuel Rail</TD></TR></TABLE>
Old Jan 9, 2004 | 07:16 PM
Doodoo's Avatar
Yeah I got you dude. I am going vtec myself now. What I am saying is based on my past experience with head work I will not do it again to the same extent as my LS head. I will spend that money on other things. I ran 8-12 psi on my semi-built motor and I was unhappy with the choices I made. Turbocharging really gets fun after 12 psi.
anavrin
Mar 22, 2011 04:57 PM
the.hamburglar
Jan 31, 2006 07:33 AM
elitetuning
Sep 17, 2005 06:58 PM
Altered
Dec 14, 2003 04:31 PM
