Comp CAM 59300 and turbo
i have heard that the Comp CAM 59300 is the same as the Zex cam 59300
the duration is 262 degrees.. etc
is this cam too agressive for turbo????
has anybody experienced a to big overlap in order to be used with turbo, even at 0 cam timing advance or retard??
any info or feedback on any other cams that have been tred with turbos??
i will only be pushing 7 psi...
how much is too much of an overlap with turbos/???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic TSI »</TD></TR><TR><TD CLASS="quote">Just do a search with 59300</TD></TR></TABLE>
Error
» No Results Found
Your search for 59300 returned no results.
Please try different search criteria or a different data set.
» Go Back
Error
» No Results Found
» Go Back
Im actually looking into them for B series motors, not sure about the D motors though.
I know the cams have high lift and moderate duration so its possible they could actually work quite well. Im not sure what the actual specs are though,
Link me to the specs page and Ill let you know what I think
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">
Error
» No Results Found
» Go Back
Strange, look at my search.
» Search Results
Your search for 59300 returned 52 results.
Error
» No Results Found
» Go Back
</TD></TR></TABLE>Strange, look at my search.
» Search Results
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Altered »</TD></TR><TR><TD CLASS="quote">Im actually looking into them for B series motors, not sure about the D motors though.
Link me to the specs page and Ill let you know what I think</TD></TR></TABLE>
http://www.compcams.com/Techni....html
i got the 59300 Cam
i got the 59300 Cam
slambedcivic
17
Apr 5, 2008 02:39 PM
fastcrxsi90
Sep 30, 2002 08:49 PM
