Bolt pattern
Old Jan 9, 2004 | 08:24 AM
elevatethis's Avatar
Default Bolt pattern
Real quick:
What the bolt pattern on a del sol (97 si if it matters) ?
4x100 or 4x114.3?
and what offset for 15" wheels?
Old Jan 9, 2004 | 08:29 AM
redlinetuning's Avatar
Default Re: Bolt pattern (elevatethis)
4 x 100
offset is +45 i think.
Old Jan 9, 2004 | 08:32 AM
Default Re: Bolt pattern (redlinetuning)
the wheels i'm looking at have a +38 offset.....will that leave them tucked in the fender? i want them to fit flush with the side of the car...
Old Jan 9, 2004 | 08:35 AM
TeamNextGenChris's Avatar
they will set pretty far out,close to flush with the fender lip.may have rubbing problems if you're pretty low.
i'm assuming these wheels are 7" wide?
chris
Old Jan 9, 2004 | 08:36 AM
Default Re: Bolt pattern (TeamNextGenChris)
6.5" actually
Old Jan 9, 2004 | 08:38 AM
you could get away with +38.. but you probably shouldn't go too low with that.. you;ll be fine at +40 7" wide.
Old Jan 9, 2004 | 08:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elevatethis &raquo;</TD></TR><TR><TD CLASS="quote">6.5" actually</TD></TR></TABLE>
that should be a little better...many people run the 6.5" wide,35mm offset Spoon/EVOs with no problems.
chris
schumi
Apr 9, 2008 10:23 PM
terd ferguson
Feb 26, 2004 12:07 PM
RDLIN-IT
May 29, 2003 12:22 PM
b18a1
Oct 2, 2001 01:11 PM
Toda Party
Sep 4, 2001 04:37 AM
