are these intercoolers good ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DroppedGSR »</TD></TR><TR><TD CLASS="quote">If you are going to chose between those i would definately suggest the Spearco IC! You could also use a johnyracecar.com IC if you arent going over 350whp!</TD></TR></TABLE>
I believe he is upgrading cause he currently is almost 350whp wanting to go 450whp and using a drag ic still... the johnracecar would be too small.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 »</TD></TR><TR><TD CLASS="quote">
I believe he is upgrading cause he currently is almost 350whp wanting to go 450whp and using a drag ic still... the johnracecar would be too small.</TD></TR></TABLE>
that is correct. shooting for 450-500 and my intercooler will get heatsoaked severly
ive sold and dealt with the ones up top from lucas and streetimports.. they ok . but not the highest of flow should be pushed in them.. for a mild setup or stock turbo car. its cool but if you want to really push some psi and do something, id go elsewhere
AssPenny
Aug 29, 2003 10:43 PM
