Who is using aftermarket fuel line with AEM rail?
I've been tring to local a fitting that goes into the fuel rail for the stock line. I talked to AEM and flamingo-T they both don't have it. If you are using the aftermarket line, I know you don't need that fitting. If you have it please let me know. I don't have the money to upgrade my stock lines and I'm missing that fitting to install my AEM fuel rail. Thanks.
You mean that -6AN (9/16" x 18tpi) port fitting?
I believe Earl's makes an AN o-ring port to AN flare adapter that you can use.
Edit: Nevermind. I know what you're talking about. Can't help you on that one. FI guys are more likely to have one laying around.
No. I have a -6AN fitting on the end of the rail right now, but it doesn't fit my stock lines. I need the fitting for the stock line. I hope you know what I'm talking about.
Thanks for the help.
I have the fitting for the rail that came with my fuel rail, it will fit into the rail and your stock banjo fitting right?
let me know by email.
jun - 5 bucks isnt worth the walk to the post office in minus 30degrees, especially for a $35 CAD part.
well, thanks anyways. I'll just get the aftermarket fuel line. Since I got the fittings for it already.
