how can you tell if MAP sensor is bad?
Old Jan 8, 2004 | 11:34 PM
SiR HatchAlot's Avatar
Default how can you tell if MAP sensor is bad?
? is there any way to test it with a voltmeter? if so, how?
B
Old Jan 8, 2004 | 11:46 PM
ARIZONA's Avatar
Default Re: how can you tell if MAP sensor is bad? (NYCautosport.com)
you can check it with a fluke multimeter. You need to check it for Voltage in a manner that it is still installed. Place the multimeter on it while car is off, should be no "E", then note the voltage while car is at idle, and not fluctuating.
Old Jan 9, 2004 | 03:54 AM
TeamNextGenChris's Avatar
Default Re: how can you tell if MAP sensor is bad? (ARIZONA)
signal output voltage should be 1.0-1.5V at closed throttle(high vacuum)and 4.0-4.5V at WOT(low vacuum),and vary between the two at throttle postitions between.
chris
Old Jan 9, 2004 | 07:52 PM
which wires should i tap into, to get this reading? anyone have a wiring diagram for this map sensor for both 92 dx and a 95 gsr?
Old Jan 9, 2004 | 08:04 PM
Default Re: (NYCautosport.com)
with the key on,there should be constant 5V on the yellow/red wire...this the voltage feed wire.
the white wire is the signal wire-it should have right at 5V with the key on,but car not running.as said above,this wire should have 1-1.5V with the car idling.
the colors are the same for both cars.
chris
Old Jan 12, 2004 | 12:06 PM
Default Re: (TeamNextGenChris)
this is where i stand right now.....i need to know which wires on the gsr map sensor do, from 'left to right' looking down at the clip.
pgk1025
May 1, 2020 07:52 AM
b18swapef
Apr 11, 2009 01:54 PM
PINKS
Jul 11, 2006 11:57 AM
Gant
May 18, 2005 08:47 PM
ProjectLudeSiR
Nov 9, 2003 10:03 PM
