how much hp on a stock b16a
i have a stock b16a w/headgasket for lower comp., its around 9:1 to 9:5 my setup is precision sc44 60 A/R comp. 48 A/R exhaust and 57 trim, inline t3 mani., turbosmart 35mm wastegate, 2 1/2 dp, 2 1/2 ic piping, precision ic, 440cc injec., vortech 12:1 fmu, 255 pump. yesterday i dynoed it at 12lbs on 91octane with 12 degrees on the timing. it layed down 270 after about 6 runs with playing with the fuel. i didnt play with it too much cause i didnt have a wideband on it, so i stopped at 270. my goal is to get 300 for the street on 91octane with hopefully 14lbs. once i get the wideband on it do you think it will hold up for 300.
I think you should be fine shooting for 300hp on the b16 block. There are several people on h-t doing it , but tuning is the key. I pretty much have the same goal for my b16 sol running on a stock bottom end! good luck to ya and remember keep that baby tuned!
