What makes a good intake?
Old Jan 8, 2004 | 10:53 PM
Matgallis's Avatar
Default What makes a good intake?
If I were to build an intake, would lengths, size, and type of material make enough difference?
Old Jan 9, 2004 | 12:09 AM
Matgallis's Avatar
Default Re: What makes a good intake? (92`Legend)
type of tubing maybe?
Old Jan 9, 2004 | 08:07 AM
Kutsuju_SLeePER is gay
Guest
Posts: n/a
air duct (used to shoot hot air out of your house)
Old Jan 9, 2004 | 09:56 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92`Legend &raquo;</TD></TR><TR><TD CLASS="quote">If I were to build an intake, would lengths, size, and type of material make enough difference?</TD></TR></TABLE>
more to do with tumble and gradual size reduction ... search fluid dynamics thats a good read for this stuff.
greg
Old Jan 9, 2004 | 02:33 PM
976's Avatar
976
New User
Default Re: What makes a good intake? (CHEETAH)
If you have a rough surface it would create turbulence. Which can decrease performance.
Many material can conduct heat, which in turn add warmth to the oxygen which decreases performance.
If the piping does not create enough velocity during the oxygen intake it can also decrease performance. Stick with AEM, they know what there doing...
Old Jan 9, 2004 | 02:39 PM
mattssi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92`Legend &raquo;</TD></TR><TR><TD CLASS="quote">If I were to build an intake, would lengths, size, and type of material make enough difference?</TD></TR></TABLE> Those are all essential parts of designing a manifold!
Old Jan 9, 2004 | 02:56 PM
Matgallis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH &raquo;</TD></TR><TR><TD CLASS="quote">
greg</TD></TR></TABLE>
I did but most of it wasn't talking about intake tubing. I guess i'll stick with aem
Old Jan 9, 2004 | 03:56 PM
8200RPM's Avatar
local hippie
Default Re: What makes a good intake? (98 Prelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 Prelude &raquo;</TD></TR><TR><TD CLASS="quote">If I were to build an intake, would lengths, size, and type of material make enough difference?</TD></TR></TABLE>
Yes.
You wanna take under consideration all of the following factors:
Inlet location (cooler location would be best), filter element (diff types have more restrictions of air flow than others), piping material (aluminum seems best IMO, although it transfers alot of heat as oppose to steel but steel holds the heat longer I believe), pipe diameter (2.5" or 3",etc).
SR20S13
Aug 2, 2007 11:21 AM
W.O.P.
Sep 12, 2004 07:49 PM
95hondaprelude
Jun 3, 2004 09:18 PM
jdmcivicferio
Apr 4, 2004 09:10 PM
kay_animation
Jun 11, 2003 07:23 AM
