How should i go about cleaning this up myself(valves,IM,ports)?
Old Jan 8, 2004 | 10:21 PM
blufke's Avatar
Default How should i go about cleaning this up myself(valves,IM,ports)?
After pulling the head off my hydroed motor the other night i come to find a good amount of carbon buildup(expected of course) and a little bit of surface rust on the head. How should I go about cleaning up the valves and surrounding chamber making it all nice and shiny(or is there even a point?). Also, my IM has some buildup(dirty oil), any recommendations on cleaning it up(what to use)along with my exhaust(had some nice rusty water sitting in them)/intake ports? here are some pics...
Old Jan 8, 2004 | 10:30 PM
mmuller's Avatar
Mad Scientist
Default Re: How should i go about cleaning this up myself(valves,IM,ports)? (blufke)
brake cleaner and a brush, seafoam works good too
Old Jan 8, 2004 | 11:09 PM
blufke's Avatar
Default Re: How should i go about cleaning this up myself(valves,IM,ports)? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">brake cleaner and a brush, seafoam works good too</TD></TR></TABLE>
what kind of brush? metal bristled brush?
Old Jan 8, 2004 | 11:41 PM
dfoxengr's Avatar
id stick with hard bristle plastic
Old Jan 9, 2004 | 09:25 AM
blufke's Avatar
Default Re: How should i go about cleaning this up myself(valves,IM,ports)? (hybridvteceg)
How much of the head do i nead to strip down to be able to hot tank it? (rockers, valves,springs,retainers)? what about guides and seals, what is the safe point to do it, so i dont damage anything?
Old Jan 9, 2004 | 09:36 AM
976's Avatar
976
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blufke &raquo;</TD></TR><TR><TD CLASS="quote">How much of the head do i nead to strip down to be able to hot tank it? (rockers, valves,springs,retainers)? what about guides and seals, what is the safe point to do it, so i dont damage anything?</TD></TR></TABLE>
Refer to B18C5-EH2, from what I noticed his SOHC was hot tanked with everything attached...
Old Jan 9, 2004 | 12:25 PM
onePOINTsix's Avatar
Default Re: How should i go about cleaning this up myself(valves,IM,ports)? (976)
I dissamble the head and first hot tank it then clean it with Purple Cleaner, that shitz great on aluminum, but dont spray it on polished metal because the polish will be wiped away
Old Jan 9, 2004 | 04:29 PM
GZERO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 &raquo;</TD></TR><TR><TD CLASS="quote">
Refer to B18C5-EH2, from what I noticed his SOHC was hot tanked with everything attached... </TD></TR></TABLE>
I wouldn't recommend it since you will ruin tha valves guide seals, for the rest, then yes, go ahead
Old Jan 9, 2004 | 05:07 PM
blufke's Avatar
Default Re: How should i go about cleaning this up myself(valves,IM,ports)? (GZERO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZERO &raquo;</TD></TR><TR><TD CLASS="quote">
I wouldn't recommend it since you will ruin tha valves guide seals, for the rest, then yes, go ahead</TD></TR></TABLE>
still toying with the idea of replace those while its all apart, and i think i can get it hottanked for free/really cheap, so i would like to get it nice and shiny.
do you need to soak the LMAs in oil if you remove them, and do they need to go back into the same positions they came out of the head in(like the rockers), i would think not. thanks.
gucci mane
Classic Hondas
Mar 16, 2011 05:48 PM
jthm
Jan 31, 2007 09:18 AM
shbrown
May 12, 2005 05:47 PM
deeksmooth
Jun 26, 2004 11:51 PM
TodaSi
Jun 8, 2002 08:54 PM
