removing intake mani
Old Jan 8, 2004 | 08:27 PM
GroundZer0 336's Avatar
Default removing intake mani
does anyone have a writeup on how to take it out.
(d16a6 by the way.)
ive got a shop manual but its not cuttin it.
Old Jan 8, 2004 | 08:49 PM
HatchBox's Avatar
Skoobie no more...
Default Re: removing intake mani (optimus_prime)
what r u having trouble with?>
unbolt the bolts that hold it to the head, get the support bolt from underneith and disconnect all hose's
91civicDXdude's Avatar
unplug everything and unbolt it
Old Jan 9, 2004 | 06:17 AM
Default Re: (91civicDXdude)
ok, cool thanks cant do it today anyways , stupid whether. decided to snow a bunch.
Old Jan 9, 2004 | 06:50 AM
neutron91's Avatar
Default Re: (optimus_prime)
when you put it back on make sure the damn gasket seals properly... i swapped a 96 ls head on my friends 90 ls and the manifold gasket didnt seal and when we started it up the tach jumped to 5000 rpms and wouldnt go any lower... it acts like a huge vacuum leak... we scratched our heads for awhile then changed the gasket and the car ran like a charm
Old Jan 9, 2004 | 06:53 AM
Default Re: (neutron91)
thats what im doin actually, is changing all my gaskets and stuff.
Old Jan 9, 2004 | 07:08 AM
neutron91's Avatar
Old Jan 9, 2004 | 10:11 AM
BdoubleU's Avatar
To remove the manifold you'll have to remove the black support bracket 3-4 bolts, and then remove the 10 or so nuts holding it on the head. Disconnect all of the hoses, fuel lines, wiring harness from injectors, and your good to go. Be sure to remember how the vacuum lines go if you've never done it before!!
Old Jan 9, 2004 | 10:55 AM
LudeEFv2.4's Avatar
My old title sucked.
new gaskets are great. what is this a winter tune up? don't forget your cam seals and water pump.
o yea, and take a little metal out of the i&e ports while your in there
Old Jan 9, 2004 | 11:06 AM
Default Re: (LudeEFv2.0)
ha i might actually take my head and intake mani to get ported since i got a little money. thers a place right down the road that will do it. im probably going to replace my head gasket too i think its starting to leak a little.
Old Jan 9, 2004 | 11:29 AM
LudeEFv2.4's Avatar
i knew i had the rite idea
elmejor
Jul 17, 2009 03:45 PM
Colombiano127
12
Jan 3, 2008 02:34 PM
extensioncordy
Jan 16, 2007 04:03 PM
boot machine 5000
Jun 17, 2002 08:26 AM
Kevin
May 22, 2002 11:18 PM
