some help on manual trannys
Old Jan 8, 2004 | 08:07 PM
AzntstyleZ's Avatar
Default some help on manual trannys
ok i just finished my swap but couple things began to give us trouble.. my car doesnt start because we accidently cut a wire near the gear box while grinding off the metal to fit the shift linkage... i reconnected the cut wire but the car still doesnt start.. why? and my taillights are on the instant my ignition is on without me touching my brakes.. is it relating the fuse under the steering column? and most importantly, when im in neutral, its really hard to shift left and right , why is that and what can i do to solve that problem?
Old Jan 8, 2004 | 09:24 PM
PushinRedline's Avatar
Default Re: some help on manual trannys (AzntstyleZ)
what kinda car, which swap??? give us more info bro.
grind the metal to fit the shift linkage???
Old Jan 8, 2004 | 09:27 PM
AzntstyleZ's Avatar
Default Re: some help on manual trannys (PushinRedline)
96 ls integra.. yea you have to grind off a piece of metal so the shift linkage can fit
zx92027xz
Sep 1, 2010 06:12 PM
stemiched
25
Aug 1, 2007 07:51 AM
Racersky
Dec 8, 2005 11:23 PM
R91Si
Nov 5, 2003 06:33 PM
