Can anyone identify this as an ITR MC/booster for sure?
Old Jan 8, 2004 | 07:42 PM
mstewar's Avatar
Default Can anyone identify this as an ITR MC/booster for sure?
About to buy this off someone, but I have no frame of reference. Just making 1000% sure that I'm getting what I need. See pic below. Thanks!
Old Jan 8, 2004 | 08:14 PM
rathead's Avatar
Default Re: Can anyone identify this as an ITR MC/booster for sure? (mstewar)
looks like it to me. one inch.
Old Jan 10, 2004 | 12:27 AM
DeuceDeuce's Avatar
Would an ITR Master Brake Cylinder work on a GSR Brake Booster?
Old Jan 10, 2004 | 06:08 AM
B18CXr's Avatar
98+ DC2 up MD/BB
Old Jan 10, 2004 | 09:58 AM
Ausmith's Avatar
Default Re: (DeuceDeuce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeuceDeuce &raquo;</TD></TR><TR><TD CLASS="quote">Would an ITR Master Brake Cylinder work on a GSR Brake Booster?</TD></TR></TABLE>
Yes it will.
Looks like a 98+ ITR MC to me. I assume the fittings on the other side are both 10mm???
If you need a GSR style - fittings on opposite sides with one being 12mm - my friend has one that is in great shape.
Mark - take a picture of your brake lines right now so I can see them.
Old Jan 10, 2004 | 04:02 PM
Smitdog's Avatar
Default Re: (Ausmith)
Marky Mark flew out to start up #55 and blow some carbon out of the Spec 3, i am sure he will check this and take some pics ASAP...
Old Jan 10, 2004 | 04:09 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (Smitdog)
either ITR or CTR...as they were the same I believe.
Teg/Civic ones had MC mounting positions like this "/", whereas the ITR/CTR had ones like picture "--"...if you see what I'm saying
Old Jan 10, 2004 | 08:06 PM
mingchi69's Avatar
I to Smooch Pickle
yea its a 1" MC, you can see it on the shaft where it says 1.
Old Jan 11, 2004 | 10:30 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ausmith &raquo;</TD></TR><TR><TD CLASS="quote">
Mark - take a picture of your brake lines right now so I can see them.</TD></TR></TABLE>
The lines up near the MC/BB? Umm.. I don't have a digicam here in the boonies, so that may be a bit of a problem.. What are you looking for?
That pic I posted is of the piece that I bought from another honda-tech person, since the Civic BB/MC was swapped onto the R.. He said it was an ITR one, I was just making sure.. That part won't arrive at my dad's til Thursday, but I'll get him to check the bolts on either side to be 10mm, since I'll be gone by then.
edit: Found this pic on the other thread that might suffice:
Old Jan 11, 2004 | 12:33 PM
JeffS's Avatar
I'm going to disagree with Ausmith and say no. The studs on the ITR booster are at 3 and 9 o'clock. The studs on a GSR booster are at 1:30 and 7:30 (top right and bottom left). This prevents mixing and matching of boosters and MC's.
Mark's picture above is definitely an ITR MC/booster.
Old Jan 13, 2004 | 10:33 AM
Ausmith's Avatar
Default Re: (JeffS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffS &raquo;</TD></TR><TR><TD CLASS="quote">
Mark's picture above is definitely an ITR MC/booster. </TD></TR></TABLE>
You are correct - I am incorrect on the GSR rig. Sorry for the confusion.
What you are buying, and what is on the car in that picture both appear to be from an ITR.
Old Jan 13, 2004 | 11:02 AM
mstewar's Avatar
Whoa.. Emerika's picture, or my picture of my engine bay?
I thought you had said you put a Civic brake booster on? Did Paul switch it out..?
I'm confused..
Old Jan 13, 2004 | 11:48 AM
Ausmith's Avatar
Default Re: (mstewar)
Paul must have switched it out. I never installed the Civic MC/booster - I couldn't as the shock tower too far pushed in. In other words I was able to get the ITR unit out, but not able to get the Civic one back in.
Old Jan 13, 2004 | 11:57 AM
mstewar's Avatar
hmm.. i was pretty sure that wasn't an ITR booster when I got it back.. I should've got a closer pic of the one currently in the car..
&lt;-- hoping he didn't waste some money on a part he didn't need.. and if he did, why the brakes are so soft..
Old Jan 13, 2004 | 11:58 AM
MattD@Stoptech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">
I'm confused..
So far, all 3 pictures in this thread show an ITR M/C B00ster....
Hope that helps...
One can not mount an ITR M/C to a civic/non-ITR integra b00ster, from what I've seen. Like stated above, only the ITR M/C-b00ster combo has the mounting bolts in a horizontal plane....the other ones are slanted...
Matt
Old Jan 13, 2004 | 01:27 PM
mstewar's Avatar
Default Re: (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">
Hope that helps...
Matt</TD></TR></TABLE>
hmm.. thank you very much for the information.. that kinda sucks for me though..
Chance EG
Mar 16, 2018 10:39 AM
omiehomie
Feb 15, 2008 04:43 PM
omiehomie
Jul 2, 2005 05:09 AM
MattD@Stoptech
Jun 10, 2003 04:58 AM
agent87
Jan 2, 2003 09:46 AM
