HOw to remove butterflies from an h22a1
Old Jan 8, 2004 | 07:36 PM
c1civic's Avatar
Default HOw to remove butterflies from an h22a1
a link or directions would be much appreiceatted, going to be switching to a p28 soon
thanks
Old Jan 8, 2004 | 07:42 PM
prelittlelude's Avatar
Default Re: HOw to remove butterflies from an h22a1 (c1civic)
well you can just unplug the wire and they will run open all the time. or you can pysically remove the butterfly plate from the mani.
go to http://www.hondaautomotiveparts.com and look for the exploded view of the intake mani and you will get the idea
Old Jan 9, 2004 | 01:07 AM
ludelvr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1civic &raquo;</TD></TR><TR><TD CLASS="quote">a link or directions would be much appreiceatted, going to be switching to a p28 soon
thanks
I did this already and I'm going with a p28. I haven't installed the ecu yet, but I've already taken out the IAB butterflies. Car still runs fine while NA. Anyway, it's pretty easy. There are two different ways you can go about this. Either take out the entire plate as in this link:
http://www.h22a.org/phpBB2/vie...#1905
or you can do what I did and just unscrew the 2 screws holding in each butterfly. I just unscrewed them cuz if you take out the entire plate, you'll need some washers to compensate for the loss in height of the intake manifold.
When you take out the plate, it's pretty easy, there are only about 4 or 5 nuts and bolts holding it on and the gasket may be a bit binding. Also, you may have to disconnect some vaccum lines and the throttle cable. I didn't even have to pull the top of the intake completely off to get that plate out. Hope this helps man.
by the way, what setup are you gonna be running?
Old Jan 9, 2004 | 04:57 AM
c1civic's Avatar
all inedd to get the motor going is my pistons and rods...i will wither be na with 12:1 comp, or be gettin 9:1 comp with around 10pounds
92eg4me
May 4, 2006 12:52 PM
NoobieREDLS
Apr 11, 2006 08:58 AM
Joe_Honda
Nov 12, 2004 09:53 PM
redboost10
Nov 26, 2003 01:17 PM
doublejz
Sep 26, 2003 01:43 PM
