Tranny pics....opinions...
Old Jan 8, 2004 | 05:09 PM
Blown90hatcH's Avatar
Default Tranny pics....opinions...
I purchased this trans off a member here and I will let the pics do the talking. Opinion please on the condition of the gears, sincs, overall trans, etc. Thanks.
Jason
Old Jan 8, 2004 | 05:25 PM
Suprdave's Avatar
Looks like it sat outside awhile...
Old Jan 8, 2004 | 05:26 PM
Default Re: (Suprdave)
How about the condition of first gear and the other sincs
Old Jan 8, 2004 | 05:28 PM
Suprdave's Avatar
Default Re: (Blown90hatcH)
1st Pic = Fairly Normal
2nd Pic = Kinda Fucked...might be able to fixit with a file.
Old Jan 8, 2004 | 05:29 PM
acy76's Avatar
That reverse gear wear in the top pic doesn't look horrible to me..
The second photo, is that the 5th-reverse synchro? Wear pattern seems odd on that one.
Old Jan 8, 2004 | 05:30 PM
Honda Hick's Avatar
Default Re: Tranny pics....opinions... (Blown90hatcH)
Those synchros are quite fucked up. Usually with normal wear, the point facing down in yer pics will round, but thats about it. Those chunks and **** and taken out of them don't look good at all. Not exactly a mint tranny.
I swear some people don't know the first thing about driving a manual transmission. I got 226,000 miles on my tranny and it's never ground once goin into gear.
Old Jan 8, 2004 | 05:31 PM
HYBRID_H@TCH's Avatar
the wear on the 1st/2nd syn collar is only on the reverse gear side and looks pretty normal from what I have seen..as for the other sync it doesnt make sense..the wear is out of range from wear the collar rides and the pointed side looks fine..kinda like someone forced it together or hammered it or something.
Old Jan 8, 2004 | 05:32 PM
Honda Hick's Avatar
BTW, can you get seperate synchros from Honda? I could for my '86 MR2 and was just wonderin about B-series trannies.
Old Jan 8, 2004 | 05:33 PM
SlowTeg's Avatar
Well, first off in your first pic I wouldn't even worry about the gear where you put red circles around the teeth, that's reverse, and since it's straight cut and doesn't have a syncro it's going to get chewed up a little, that's normal...
In your second pic the syncro definetly looks pretty chewed up, at least compared to some that I've seen. I think the triangular part is the only real important part of the syncro that does the work, so I'm not sure how much the sides being chewed will make a difference. Can you take some more shots of the gears?
It looks like it sat outside for a bit, but I wouldn't worry about that too much.
-Mike
Old Jan 8, 2004 | 05:35 PM
acy76's Avatar
Default Re: Tranny pics....opinions... (Honda Hick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Hick &raquo;</TD></TR><TR><TD CLASS="quote">
I swear some people don't know the first thing about driving a manual transmission. I got 226,000 miles on my tranny and it's never ground once goin into gear. </TD></TR></TABLE>
Agreed. As far as synchros from Honda, I have heard you have to get the whole gearset (not all 5, but you know what I mean). There is a company that sells aftermarket rebuild kits here: http://www.transtarindustries.com/default.asp
They seem to come with or without synchros. You'd have to call them up for some real info.
Old Jan 8, 2004 | 05:38 PM
SlowTeg's Avatar
To my knowledge you can't, or at least I can't, get individual syncros from honda. You usually have to purchase a gear set which usually includes like the gear(s) itself, syncros, synchro hub, etc..
-Mike
Suprdave's Avatar
Default Re: Tranny pics....opinions... (acy76)
Hmmmm, It almost looks like there was a piece of debris in there.
Old Jan 8, 2004 | 05:41 PM
acy76's Avatar
Default Re: Tranny pics....opinions... (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">Hmmmm, It almost looks like there was a piece of debris in there.</TD></TR></TABLE>
I was just thinking the same thing. Or someone tried to tap the assembly onto the shaft when putting it together.
Old Jan 8, 2004 | 05:42 PM
SlowTeg's Avatar
Have you had any experience w/ aftermarket replacement parts like this company? People have mentioned them, but when I fixed my trans I was worried that they wouldn't last as well as the oem parts, and I don't know anyone personally that's tried aftermarket replacement trans parts. Thanks.
-Mike
Old Jan 8, 2004 | 05:45 PM
acy76's Avatar
Default Re: Tranny pics....opinions... (SlowTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowTeg &raquo;</TD></TR><TR><TD CLASS="quote">Have you had any experience w/ aftermarket replacement parts like this company? People have mentioned them, but when I fixed my trans I was worried that they wouldn't last as well as the oem parts, and I don't know anyone personally that's tried aftermarket replacement trans parts. Thanks.
-Mike</TD></TR></TABLE>
Nope, just read about them on a forum somewhere. If I needed synchros, I'd probably call them though. Heard a rebuild kit was around $450, which is probably lots cheaper than the dealer.
Old Jan 8, 2004 | 05:49 PM
hybridEj6's Avatar
get some sychromesh and flush it out with it and then put some in there
Old Jan 8, 2004 | 06:21 PM
Honda Hick's Avatar
Default Re: Tranny pics....opinions... (ekhybrd)
I don't think some kinda fluid is going to put those synchros back together . It would be dumb to put it back together looking like that
B18bEK's Avatar
looks like barnacles have grown on your tranny
Old Jan 8, 2004 | 06:25 PM
Yeah, this was definately not what I expected to see.
Old Jan 8, 2004 | 10:04 PM
hybridEj6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Hick &raquo;</TD></TR><TR><TD CLASS="quote">I don't think some kinda fluid is going to put those synchros back together . It would be dumb to put it back together looking like that </TD></TR></TABLE>
but it will help when i put gm sychromesh in my car is actually changes gears a lot smoother and it also prevents tranny wear which honda trannys get a lot off
Old Jan 8, 2004 | 11:54 PM
Kwuaymaikrup's Avatar
The reverse gear doesn't look to bad but the 2nd pic is fucked. You can get separate sets from Honda though so that won't be a problem As far as the case goes. I would pull it all apart and have it sand/bead blasted and get that rusty bolt or whatever replaced. As far as the seller goes I would definatally try and get some sort of compensation if the tranny is not what he implied he was selling. Maybe have him pay for the sandblasting???
-Ryan
Old Jan 9, 2004 | 12:58 AM
CRX-RX's Avatar
Default Re: Tranny pics....opinions... (Kwuaymaikrup)
You don't have to buy whole gear sets from honda, just a collar shaft/synch hub/synch set for whatever section you're replacing. It looks like there was low fluid if indeed that is 5th, or a very poor fluid. I would also make sure the input shaft bearing is in good working order. That synch had to of locked up at one point and been forced back to the neutral position. I would take it apart and check the cone for signs of burning. That fifth gear doesn't look to promising either. Don't know what you paid, but if it was more than $300 I'd be really upset
Old Jan 9, 2004 | 05:31 AM
Default Re: Tranny pics....opinions... (CRX-RX)
700
Old Jan 9, 2004 | 02:34 PM
b18cls1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowTeg &raquo;</TD></TR><TR><TD CLASS="quote">To my knowledge you can't, or at least I can't, get individual syncros from honda. You usually have to purchase a gear set which usually includes like the gear(s) itself, syncros, synchro hub, etc..
you can get the syncro assembly alone with out the gear but you cant get just the brass which is the only real part you need
Race Egr
12
Mar 2, 2005 12:45 PM
snatch
Jul 20, 2004 05:11 PM
squirrel
Feb 20, 2003 04:55 PM
newspeedR
Jul 18, 2002 01:16 PM
