CEL CODES
Old Jan 8, 2004 | 04:48 PM
NAB16AEK's Avatar
Default CEL CODES
Just used them thought that I would post them for future reference.
For 96-98 Civic / 97-98 / CRV 96-98 / Prelude / 94+ Integra
CODE DEFINITION
1 Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor
2 Oxygen Sensor "B" defective circuit or unplugged / defective sensor
3 MAP Sensor (Manifold Absolute Pressure) defective circuit or unplugged / defective sensor
4 CKP Sensor (Crankshaft Position Sensor) defective circuit or unplugged / defective sensor
5 MAP Sensor (Manifold Absolute Pressure) mechanical problem / disconnected piping* not 94-95
6 ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor
7 TP Sensor (Throttle Position) defective circuit or unplugged / defective sensor
8 TDC Sensor (Top Dead Center) defective circuit or unplugged / defective sensor
9 CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor * invalid code for throttle body injection Hondas** invalid code for V6 engines
10 IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
12 EGR Lift Sensor (Exhaust Gas Recirculation) defective circuit or unplugged / defective sensor* invalid code for non-equipped EGR valve vehicles
13 BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor
14 IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
15 Ignition Output Signal missing or defective ignition output signal
16 Fuel Injector System defective circuit or unplugged / defective fuel injector
17 VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor
19 Automatic Transmission Lock Up Control Solenoid Valve defective circuit or unplugged / defective solenoid valve
20 Electrical Load Detector defective circuit or unplugged / defective sensor
21 VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve* invalid code for non-VTEC engine** invalid for V6 engine
22 VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch* invalid code for non-VTEC engine
23 KS (Knock Sensor) defective circuit or unplugged / defective sensor* invalid code for V6 engine
30 Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB defective circuit or unplugged / defective sensor* invalid code for 1996
31 Automatic Transmission Signal "B" defective circuit or unplugged / defective sensor
41 Primary Oxygen Sensor - Heater circuit malfunction
43 Fuel Supply System defective or malfunctioning fuel supply system
45 System Too Lean or Too Rich malfunction in the fuel monitoring systems
48 LAF Sensor (Lean Air Fuel) defective circuit or unplugged / defective sensor
54 KF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor
61 Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response
63 oxygen Sensor, Heated - Sensor 2 (Secondary) high voltage, low voltage, or slow response
65 Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater
67 Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
70 Automatic Transmission malfunction with the automatic transmission controls
71 Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
72 Cylinder 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
73 Cylinder 3 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
74 Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
Old Jan 19, 2004 | 03:43 PM
FinchMonster's Avatar
you are the man, i really needed those and knew i could come here :D
Old Jan 19, 2004 | 03:53 PM
MrTodd's Avatar
Default Re: (FinchMonster)
Where can I find OBD-1 codes?
Old Jan 19, 2004 | 06:12 PM
NAB16AEK's Avatar
Default Re: CEL CODES (NAB16AEK)
thanks man.
Old Jan 19, 2004 | 06:19 PM
hondatim's Avatar
Default Re: (MrTodd)
These are the same numerical codes as OBD 1 codes also, with the exception of the evap emission codes and heated O2 codes and obviously codes that do not apply to your engine.
For example: if have code 1 on you OBD1 car, still means O2 sensor.
etc, etc.
efyou999
May 24, 2012 12:21 AM
sh!ft
May 13, 2009 01:18 PM
sharky8513
12
Feb 5, 2005 08:25 AM
jpangeles
Sep 12, 2004 05:23 PM
eh2_b20z
Feb 10, 2003 09:54 AM
