Possible to fix this "dent" (big)
Old Jan 8, 2004 | 03:53 PM
dumbchild's Avatar
Default Possible to fix this "dent" (big)
My rear quarter panel just went from good to bad...
How possible would it be to fix this dent as much myself before taking it to the bodyshop. Is there any way to either pull it out or push it from the interior side? Or should I just give up and pay the bill?
Before:
After:
Old Jan 8, 2004 | 03:55 PM
^jefs0ng's Avatar
Banned
that might be able to be "banged" out. My friend had a dent some what like that in her QP of her camry too. We just went into the trunk and bangde it out, looked perfect. But yours is a bit bigger, the "cracks" look a little more "complicated"
Old Jan 8, 2004 | 03:58 PM
EJ1_519
Guest
Posts: n/a
Default Re: Possible to fix this "dent" (dumbchild)
What you should do is where you have the deepest folds in the metal, you should drill holes in the area and get a special tool that you slide in and you can pull out the body panel into better shape
TRE_'s Avatar
that looks like it'd be a bitch to fix.... i'd definantly take it to a body shop
Old Jan 8, 2004 | 04:00 PM
dumbchild's Avatar
Default Re: (.jefs0ng)
I thought it might be able to be banged out like you described.
Does anyone know if that area is accesible from the interior - or is there sheet metal blocking the way?
Old Jan 8, 2004 | 04:02 PM
dumbchild's Avatar
Default Re: Possible to fix this "dent" (EJ1_519)
Is the drilling method the most effective way to start?
I guess maybe I'll try banging it out first and then if that doesn't get it all out start drilling.
I just want to save time in the bodyshop to lessen the bill. haha
Old Jan 8, 2004 | 04:05 PM
bryant's Avatar
I say weld in a new qaurter.
Old Jan 8, 2004 | 04:51 PM
EJ1_519
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumbchild &raquo;</TD></TR><TR><TD CLASS="quote">Is the drilling method the most effective way to start?
I just want to save time in the bodyshop to lessen the bill. haha</TD></TR></TABLE>
Well if you start banging on it, you will ruin the way the metal folds. First I would pull it with the pulling tool(hole method) to get it as accurate as possible, then i would bang out as much metal as possible.
Old Jan 8, 2004 | 05:32 PM
dumbchild's Avatar
Good point. I guess ideally with the pulling tool it would "pop" back out exactly the same way as it popped in.
Bryant:
I think welding in a new quarter is probably the most expensive solution - not exactly what I'm looking for...
rfmerrill
Paint and Body
Oct 13, 2017 10:30 PM
Stock EJ8
Paint and Body
14
Jun 17, 2011 02:49 PM
-[95cxhatch]-
14
Feb 14, 2006 08:31 AM
SPORT INJECTION
17
Dec 15, 2005 11:27 AM
NXLude
Oct 11, 2005 05:21 PM
