alarm kill start question
Old Jan 8, 2004 | 03:51 PM
ThrillaKilla's Avatar
Default alarm kill start question
ok well i disconnected my positive terminal connector to save battery life while car was being operated on.. and my alarm popper does not work so theres no way to turn the alarm off when i reconnect the positive battery cable, is there any way to disable the alarm from coming on? ive dissconnected everything from the alarm box but it still has a kill start somewhere that must bypass the alarm or something is what im thinking... is there any way to bypass this problem i just need to start it up and test something, then ill go get the popper fixed! thanks!
Old Jan 9, 2004 | 02:05 AM
Default Re: alarm kill start question (ThrillaKilla)
bump it up
Old Jan 9, 2004 | 07:38 PM
baphomet's Avatar
I wouldn't post this kind of information, we have enough problems with theft as it is.
Old Jan 9, 2004 | 10:22 PM
Default Re: alarm kill start question (slashDEVslashNULL)
its my integra look at my previous posts and youll be pleased to find out its mine... i just need to know but if your all scared like that whatever
Old Jan 10, 2004 | 09:09 AM
Wes V's Avatar
If what you are saying is that you don't want the alarm to automatically going off when the battery is disconnected and then re-connected, the answer is easy.
In most of the cars that I've built, I've installed a large switch (SCCA approved and available through Summit Racing) to turn off the battery. Bypassing this (and going through as small a fuse as possible!) is the power going to the alarm. This way, the alarm always has power and will function. The reason for making the fuse as small as possible is so that a thief only has a limited amount of amps to start the car.
Keep in mind that I normally fabricate a solid lock to keep the hood closed.
Wes
Old Jan 12, 2004 | 02:13 PM
Civic-Ex-98's Avatar
What kind of alarm?
Some alarms have a valet switch/keypad, you can enter a seq. code that will bypass the stater disable. Talk to the shop near you that sells your brand of alarm.
Old Jan 12, 2004 | 07:07 PM
Default Re: alarm kill start question (Civic-Ex-98)
thanks yeah i do have a switch.. didnt want to have it come to goin to a shop but i guess its inevitable.... ill just get the popper fixed at that time.. love it when all this stuff happens when im tryin to sell it ha
13_seriez
Jun 24, 2011 06:42 PM
Midgetmax4
Mar 31, 2007 06:27 AM
dukers
Jul 18, 2005 05:39 PM
95 Gizzer
Mar 27, 2003 05:44 PM
BringIT
Audio / Security / Video
Dec 27, 2001 07:50 PM
