Which to chose and where to find?
Old Jan 8, 2004 | 03:04 PM
sillvercivicgsr's Avatar
Default Which to choose and where to find?
I'm looking for a hydrualic transmission for my eg hatch with a b18c1 swap. Here are my mods - dcsports 4-2-1 header, aem cam gears and intake, skunk2 intake manifold, crower 402 cams valve springs and retainers, june chip, skunk2 vtec controller, clutchmasters stage 3 clutch and flywheel, b&m pro short shifter, kyb adjustable struts, nuespeed lowering springs, unothodox racing crank pulley, 16" enkie racing wheels, powerstop slotted rotors, fluidyne radiator, 3" cat back exhaust. Which b-series transmission should I go with, where should I get it from, and what should I expect to spend on it?
Old Jan 8, 2004 | 03:10 PM
OpTiX619's Avatar
Default Re: Which to choose and where to find? (sillvercivicgsr)
if you want small gears... go with a b16 it has the smallest next to the R. if your not so worried about gear ratios.. go with the gsr b18c... less to worry about because it is stock for your motor.... in san diego, trannys go for about 450 to 650 depending on type.
Old Jan 8, 2004 | 03:13 PM
Ricey McRicerton's Avatar
Default Re: Which to choose and where to find? (OpTiX619)
ITR and B16 transmission gearing is the same. (with the exception of the latter years with the shorter FD) The C5 tranny is the same tranny with a LSD.
If you've got the money get the ITR tranny with the LSD, if not grab a B16 tranny. The shorter gearing will lead you to better accelleration, but will lead to a higher cruising RPM.
Old Jan 8, 2004 | 03:17 PM
DaX's Avatar
DaX
Loved
Community Favorite
Cable J1 with HAsport conversion.
Old Jan 8, 2004 | 03:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OpTiX619 &raquo;</TD></TR><TR><TD CLASS="quote">if you want small gears... go with a b16 it has the smallest next to the R. if your not so worried about gear ratios.. go with the gsr b18c... less to worry about because it is stock for your motor.... in san diego, trannys go for about 450 to 650 depending on type.</TD></TR></TABLE>
Is that 450-650 shipped or would I have to spend more for shipping? Is it a new or rebuilt tranny?
Old Jan 8, 2004 | 03:41 PM
Jimmy's Avatar
Global Moderator
i would definetly get the b16 tranny
Sixfortyfive
13
Jul 10, 2008 07:39 AM
JDM_EK4_Coupe
Mar 7, 2007 07:56 PM
jdm_sir2
18
Sep 7, 2006 01:53 PM
sillvercivicgsr
Jan 12, 2004 03:36 PM
sillvercivic
Jan 2, 2004 04:55 AM
