whats the easiest way to remove an axle?
Old Jan 8, 2004 | 02:48 PM
keebler65's Avatar
Default whats the easiest way to remove an axle?
i'll be doing a clutch install soon on my bro's LS, and i'd like to know what you guys commonly take apart to get the axles out with the least amount of effort. please be detailed....i'm not looking forward to this weekend
thankyou
Old Jan 8, 2004 | 02:56 PM
garados's Avatar
Default Re: whats the easiest way to remove an axle? (keebler65)
https://honda-tech.com/zerothread?id=711961
Old Jan 8, 2004 | 03:17 PM
keebler65's Avatar
Default Re: whats the easiest way to remove an axle? (garados)
from what it seems, all hondas are pretty much alike when it comes to axles, is this correct? i've done it on EF's before....will the integra be very simliar?
Old Jan 8, 2004 | 03:31 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keebler65 &raquo;</TD></TR><TR><TD CLASS="quote">from what it seems, all hondas are pretty much alike when it comes to axles, is this correct? i've done it on EF's before....will the integra be very simliar?</TD></TR></TABLE>
D-series engines have a long axle on the driver side and a short one on the pass. side. B-series engines have a center halfshaft that bolts to the block, and then equal length axles on both sides. It's better to remove both axles and then the halfshaft separately, but if you have trouble getting the driver side axle off the halfshaft, then you can just remove both together as one unit, similar to the 1 long axle on D-series engines. Keep in mind the 2 pieces together will be pretty heavy, so have a friend helping.
Old Jan 8, 2004 | 10:54 PM
PushinRedline's Avatar
take all the necessary bolts and nuts off. Use a pry bar and pry where the axle meets the tranny case. Might need to use a flat head screw driver to open the slot a bit bigger to fit the pry bar.
whatever you do, dont pull on the axles.
jimep386
May 26, 2007 10:06 AM
GarageAlchemist
Jul 20, 2006 06:38 PM
crxgsr91
Oct 22, 2004 02:51 PM
mongoliandonuts
30
Feb 15, 2004 09:51 AM
coupedup
Jun 9, 2003 10:49 PM
