J&S sensitivity with turbo itr?
Even at low boost (5 lbs.) and the lowest sensitivity possible (8 o clock) I get 1-2 lights occasionally (2-4 degree retard). J&S will desensitize the unit if I want to send it back. Should I do it? Before the J&S install, I was running 7-8 lbs for over a year with no problems. I would like to run 10-12 lbs safely. Anyone know what the optimum boost retard start and rate settings might be? Thanks.
