HELP! power locks not working
Ok having some trouble with my power locks. I checked the fuse and its still good, check for power to the power window control module, check, checked for power to the switch, no power, obvioulsy it has to be the power window control module right? I just want to get some opinions, I'm guessing there is some kind of actuator to move the locks up and down, could that have failed also? Basically my switch is doing nothing and I can lock the driver door with the key fine. I'm pretty sure its the control unit, just wanted to make sure I'm not over looking anything before I go to the junkyard and pull one cuz they are 140 new from Honda (ouch)
thanks
thanks
power lock controll box. its inside the drivers door. check for power into and out of the unit with a multimeter. 80% sure thats where your problem is.
its the grey box in the middle of this picture
its the grey box in the middle of this pictureTrending Topics
i'm gonna go try the new module first then if hat dosent work who knows. when i check out the wiring diagram the power goes into the fuse boc hen to the module hte to switch and I have power to the module just not the switch... so must be the module
4playEkay
Mar 31, 2005 10:48 PM
