84mm B18c1 with pt67, what flywheel?
I did some searching and I think I want to go with a stock gsr flywheel, but my problem is can I go with an aftermarket "stock" flywheel or should I go with genuine honda flywheel? Or maybe I should go with something completely different? This will be going in a DRAG RACING vehicle btw. Also, where is the best place to get any of the above?
What do you guys think?
Thanks in advance
Thanks in advance
Well if you want it for drag racing then you should go with a SFI approved flywheel. The ACT flywheel is nice. Solid billiet iron, no alum. Get the street lite version though it has a little more weight which helps for turbo cars from what I understand.
VtecInteg95
Dec 11, 2003 03:04 PM
Nealoc187
Apr 1, 2003 09:51 AM
