Anyone else's brakes sticking?
Hey all, the rear right caliper on my 96 gsr sedan is sticking...not too serious, but enought to squeal a little....its going to get replaced, the master cylinder too, but i was just wondering if anyone else has had or is having the same issue?
both my rear calipers stick and at low speeds (2-3mph) you can hear the squealing of the pad touching the rotor. I took them off about a year ago, took them apart and clean and lubed up everything and it cured it for a while but it eventually came back gradually. They work fine so i'm not really that bothered about them right now, but it is a common fault on both EG civics and DC2 integras (not sure about ITRs though)
thanks....i had heard the thing about the pins..but i think its my master cylinder, cus the pedal will go to the floor on hills, and the brakes will give
SlowB16
Sep 7, 2013 12:41 PM
