mini-me qesstion pls help asap
hi i just broke the time belt for my mini me setup
a6 block with y8 head...
so wanna know whh timing belt i should get and also need to know will any damage coz by broken timing belt like bent valve , oil pump, water pump,or else..
pls need
pls need
y8 belt
while you are there you may as well do the water pump.
gonna have to check the head to see if the valves are bent, sometimes they do, some times they don't.
Good luck.
Good luck.
I think the bigger question here is why did the belt break? it obviously couldnt've been on there too long.. was it extremely tight? I know when I started doing a mini me..the tbelt was way way too tight...
lilskud13
14
Mar 26, 2009 01:28 PM
davken1102
16
Jan 10, 2004 09:24 AM
loclowd
May 6, 2003 08:07 PM
