96-00 civic hatch swaybar fitting
Old Jan 8, 2004 | 08:27 AM
jimmhatch's Avatar
Default 96-00 civic hatch swaybar fitting
would a 94-98 GSR front swaybar fit on an 96-00 ek hatch?
Old Jan 8, 2004 | 08:31 AM
gubo22's Avatar
New User
Default Re: 96-00 civic hatch swaybar fitting (jimmhatch)
From my experience NO
I physically tried it myself and it did not fit.
I had to send it back and ordered a 96-00 sohc vtec front sway bar.
Keep in mind you will also need the front lca's from that model as well.
You could also use a 99-00 Si (thicker) front sway bar but then you would have to change the lca's and front forks aswell.
Old Jan 8, 2004 | 09:22 AM
Dr. EKology's Avatar
Default Re: 96-00 civic hatch swaybar fitting (gubo22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gubo22 &raquo;</TD></TR><TR><TD CLASS="quote">
You could also use a 99-00 Si (thicker) front sway bar but then you would have to change the lca's and front forks aswell.</TD></TR></TABLE>
Good advice! Or you could look into a CTR Front sway. The only DC chassis bars that will work is the ITR rear sway w/ the use of the Beaks kit.
Leady
Apr 10, 2010 12:47 PM
deviant1
Jun 27, 2007 03:29 PM
Santys EK
Aug 12, 2006 07:51 AM
stealth_EK4
Northern California (Sales)
Oct 4, 2005 09:56 AM
wdskuk
Sep 21, 2003 08:17 PM
