crappy start up on b16
Old Jan 8, 2004 | 07:28 AM
jdmlsvtecrx's Avatar
Default crappy start up on b16
ive got a 1st gen b16 in my crx with a type r mani... when i start up when cold its hard to rev up and almost wants to die... when you you rev it just stumbles... what the hell is the problem,, i think something with my injectors.....somethings fishy..
Old Jan 8, 2004 | 07:53 AM
wickedEFguy's Avatar
Default Re: crappy start up on b16 (jdmlsvtecrx)
so this happenes only in the morning when your starting up? Have you checked for codes yet....
Old Jan 8, 2004 | 12:24 PM
Default Re: crappy start up on b16 (wicked B16)
it only does it if the car has been off for a few hours...... runs fine after it warms
up though
no codes thrown
Old Jan 8, 2004 | 12:35 PM
turboxsi's Avatar
Its most likely because you have the type-r i/m. Using that intake manifold elimates the Fast idle thermal valve (FITV), which aids the engine in a cold startup, so without it you run a bit rougher on a cold startup. Which is why it runs fine after it warms up.
I have the same deal with my 1st gen b16, just let it warm up a bit before you drive it.
Old Jan 8, 2004 | 12:45 PM
cstay's Avatar
Default Re: crappy start up on b16 (turboxsi)
would the same thing happen if u disconected the coolent lines going to your tb to run cooler? i hear that diy trick gains a fiew hp but only to run it in warm conditions this must be why.
Old Jan 8, 2004 | 01:46 PM
turboxsi's Avatar
Default Re: crappy start up on b16 (cstay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cstay &raquo;</TD></TR><TR><TD CLASS="quote">would the same thing happen if u disconected the coolent lines going to your tb to run cooler? i hear that diy trick gains a fiew hp but only to run it in warm conditions this must be why.</TD></TR></TABLE>
I don't think that will cause the same problem. I have my coolant lines hooked up to t/b and have the problem b/c my FITV is removed, only takes like a minute to warm up and everything is fine.
jurenic
Jan 7, 2011 08:59 PM
efnick
Oct 18, 2008 04:36 AM
b16_madman
Dec 7, 2003 02:07 PM
b16_madman
Dec 7, 2003 01:06 PM
