Fans not working
Old Jan 8, 2004 | 05:38 AM
TechNetOk's Avatar
Default Fans not working
My fans do not come on after replacing the radiator. I plugged up both fans as they were but before one would come on when the key was turned on, but now its not coming on at all.
Old Jan 8, 2004 | 05:41 AM
4DRPIMPIN's Avatar
Default Re: Fans not working (TechNetOk)
Check the fuses, if not that check fan switch on block..
Old Jan 8, 2004 | 12:31 PM
scrubachu's Avatar
Default Re: Fans not working (4DRPIMPIN)
you can go ghetto like me and splice the cooling fan into your headlight relay. that way you can cool your motor whenever you want. hahaha. yea, im too lazy to find the break in the wire wherever it is.
Old Jan 8, 2004 | 01:00 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DRPIMPIN &raquo;</TD></TR><TR><TD CLASS="quote">Check the fuses, if not that check fan switch on block..</TD></TR></TABLE>
if not that then run a hard line with a on/off switch for them..
Old Jan 8, 2004 | 08:10 PM
TechNetOk's Avatar
Both fans come on when the AC is turned on. Is one of the fans suppose to come on when the key is turned on?
Old Jan 8, 2004 | 09:05 PM
whoa its len 2's Avatar
I have no a/c fan no more. The other fan on the passenger side doesnt work on mines either. It goes on sometimes but only when the car is off. Im just to lazy to check whats wrong.
Old Jan 9, 2004 | 09:38 AM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TechNetOk &raquo;</TD></TR><TR><TD CLASS="quote">Both fans come on when the AC is turned on. Is one of the fans suppose to come on when the key is turned on? </TD></TR></TABLE>
your fans are wired wrong some how. one comes on with the a/c the other comes on at a certain temp...
Old Jan 9, 2004 | 09:50 AM
JimBlake's Avatar
Default Re: Fans not working (bagged93accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord &raquo;</TD></TR><TR><TD CLASS="quote">your fans are wired wrong some how. one comes on with the a/c the other comes on at a certain temp...</TD></TR></TABLE>That's only true for certain years. Mine both come on together with AC as well as coolant temperature.
Old Jan 9, 2004 | 11:29 AM
.bagged's Avatar
Default Re: Fans not working (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">That's only true for certain years. Mine both come on together with AC as well as coolant temperature.
oh what year are we lookin at..?
peteyparado
May 12, 2013 08:43 AM
Eglifestyle
10
Mar 23, 2008 12:08 PM
Black Paper Diary
May 19, 2006 03:16 PM
ViXoN Hatch94
Feb 4, 2006 07:53 PM
wsiracerz
Jun 7, 2004 01:59 PM
