? about axles for 5 lug conversion
Old Jan 7, 2004 | 10:30 PM
253EK's Avatar
Default FINALLY!: ? about axles for 5 lug conversion
sup fellow members.
planning on doing a 5 lug conversion but heard that the jdm one isnt good because the axles are hard to get. is this true and where can i find them? should i just wait to come upon a usdm or even ctr 5 lug conversion?
help needed ASAP
thanks again
Modified by 253EK at 3:42 PM 1/17/2004
Old Jan 7, 2004 | 10:32 PM
MaxSterling's Avatar
Default Re: ? about axles for 5 lug conversion (darren94rs)
i heard thru the grapevine that you can use crv axles for jdm 5 lug itr. but i am not sure and have nothing to back it up....anyone one HT can confirm/deny?
Old Jan 8, 2004 | 01:23 AM
b00sted93Hatch's Avatar
Default Re: ? about axles for 5 lug conversion (MaxSterling)
Not sure bout the Crv thing but I'm pretty sure not all jdm 5 lugs had the 36mm axle spline. Try finding some USDM 5 lug if your worried.
Old Jan 8, 2004 | 01:34 AM
clownsrevil's Avatar
Default Re: ? about axles for 5 lug conversion (allMotor93Hatch)
The conversions for these lugnuts is as follows 1-3-4-5-2 just remember to put the 5th one in the fifth lugnut spot and you should be fine.
Old Jan 8, 2004 | 04:58 PM
253EK's Avatar
Default Re: ? about axles for 5 lug conversion (clownsrevil)
thanks
any other opinions or facts?
TTT
Old Jan 8, 2004 | 05:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clownsrevil &raquo;</TD></TR><TR><TD CLASS="quote">The conversions for these lugnuts is as follows 1-3-4-5-2 just remember to put the 5th one in the fifth lugnut spot and you should be fine.</TD></TR></TABLE>
are you on crack?
Old Jan 8, 2004 | 05:46 PM
Sukebei Oni's Avatar
usdm and ctr axle have a 26 spline outer spindle, with a 32 mm nut.
the JDM ITR's have a 28 spline outer spindle, with a 36 mm nut.
yes the JDM are harder to get, since most sell the axles with the conversion, so if you need to replace one, you might have trouble finding one.
However, i have also heard that the CRV axles will fit the same as the JDM ITR. I have not tested this theory yet, so i can't say for sure.
Old Jan 8, 2004 | 05:57 PM
jdmvtec28's Avatar
98 Spec ITR Suspensions use 36mm axles consequently Preludes use the same thing, rumor has it that the outer CV joints are compatible. Otherwise if they are not included you will play hell finding them. The plus to the bigger axles is that is if your motor is heavily modified it is extra strength. I am not positive about the outer CV joints but am fairly certain. Additionally there are crazy JDM importers that specialize in sourcing JDM parts but they are kind expensive
Old Jan 8, 2004 | 06:04 PM
Default Re: ? about axles for 5 lug conversion (jdmvtec28)
i'm not so sure about the prelude axles. i've heard of people having problems making them work.
Old Jan 8, 2004 | 08:58 PM
253EK's Avatar
Default Re: ? about axles for 5 lug conversion (Sukebei Oni)
i know there has to be someone out here who has first hand experience
HELP
thanks to the replies
Old Jan 9, 2004 | 08:49 AM
jdmvtec28's Avatar
I do have first hand experience, I got a JDM 5 lug in with no axles and was pissed, called back the place where I got the suspension from and threatened to run a chargeback on my CC. So they sent me the outer CV joints out from a JDM ITR. I had to take swap them out.
Old Jan 9, 2004 | 12:50 PM
253EK's Avatar
so jdm axles are a must for the jdm 5 lug conversion?
TTT
Old Jan 9, 2004 | 01:21 PM
jdmvtec28's Avatar
Quit playing... Read the posts above, I have first hand experience working with the JDM suspension, my solutution was to call and bitch and the company that sent them to give me the ITR outer cv joints.
Given the fact that almost all honda's have interchangable parts I find it unlikely if not impossible that no other honda or acura CV joint would work. Be it CRV Prelude or whatever...
I am trying to contact a couple connects I have in cali to see if I can source a pair of JDM axles, Don't hold your breath though, just do what I can do.
Old Jan 9, 2004 | 04:34 PM
ThePro's Avatar
I have a letter into The Driveshaft Shop about starting production of these axels. I'll let everyone know if they end up happening.
Old Jan 16, 2004 | 10:26 AM
ThePro's Avatar
Update:
driveshaftshop.com says they have made axels to fit the JDM ITR 5-Lug swap. They don't have them listed on their website, but they are supposed to be the same price as the regular Integra axels.
Old Jan 17, 2004 | 06:43 AM
253EK's Avatar
Default Re: (ThePro)
i finally got my car back on the ground....thanks to all for your support.
i'll have pics up soon
Old May 20, 2004 | 08:08 PM
iNetForce's Avatar
Default Re: (253EK)
picssss?
jc2801
Jun 7, 2007 10:05 AM
cashkid2004
Oct 1, 2006 06:41 AM
h22teg
Mar 28, 2005 07:09 AM
TheHater
Dec 20, 2002 07:58 AM
