broke my car tonight
well, i was at the track tonight and on my launch i heard a loud snap, crackel, crunch,
i immediatly shut down and pulled to the side. i'm hoping it's only an axel but after further thought i'm scared it might not be.
the car was still running fine so i know its not the motor
but nothing was hanging down and the car rolled fine with out making any noise. as soon as it's in gear and i let the clutch out it makes a terrible grinding noise and starts to jerk. has anyone ever ran into a problem like this before?
i have an ACT clutch (HD pres. plate, six puck) could this cause the jerking when i let the clutch out trying to turn the other axel? hopefully it's not too serious, like a destroyed tranny!
let me know if you guys can think of anything it could be. thanks! sorry this is so long
i immediatly shut down and pulled to the side. i'm hoping it's only an axel but after further thought i'm scared it might not be.the car was still running fine so i know its not the motor
but nothing was hanging down and the car rolled fine with out making any noise. as soon as it's in gear and i let the clutch out it makes a terrible grinding noise and starts to jerk. has anyone ever ran into a problem like this before?i have an ACT clutch (HD pres. plate, six puck) could this cause the jerking when i let the clutch out trying to turn the other axel? hopefully it's not too serious, like a destroyed tranny!
does the car move????if it doesnt could be 2 things a blown dif(which could happen depends tho) or the joint in the axle is completely destroyed i snapped my axle like that doing a burnout in the staging area and didnt notice it until i tried to move and it went no where. just reved and made a weird noise.
jack the car on stands, take the wheel off and start teh car. put the car into gear and look to see if one side isnt moving. look at the halfshafts on the axle too see if its spinning if one side isnt and see if the boot isnt moving. then u just snapped an axle. common with people more likely than a dif unless u got some serious hp
yeah the car moves, rolls like nothing is wrong. that does make alot of sence! never even thought about the joint or diff. thanks man. i had it towed to my work so we can take it apart tomm. sure am glad i work at a honda dealership. (just a tinter though) i would just like to go in with as many "could be's" as poss. not makin serious pwr. only 170 whp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99skunkedSi »</TD></TR><TR><TD CLASS="quote">yeah the car moves, rolls like nothing is wrong. that does make alot of sence! never even thought about the joint or diff. thanks man. i had it towed to my work so we can take it apart tomm. sure am glad i work at a honda dealership. (just a tinter though) i would just like to go in with as many "could be's" as poss. </TD></TR></TABLE>
no prob **** i was scared as hell peopel where telling me i blew my trans and **** i was shitting a brick because i didnt have money to dump a new tranny in. and then one of my buddies at werk( i also werked at honda) a tech told me to do that. and **** enough i did and when i felt the boot wow all i felt was like rocks in a bag lol.
I was running a unsprung 6 puck with a B16 tranny on my GSR motor and something similar happen to me. What I believed happen was the the clutch causing to much shock and blew the tranny. b16 trannys are known for being weak. I think i broke the ring gear and I drove it home anyways bad idea haha and it just locked up. Pull the tranny and there was a big hole in it and pulled the casing and all the gears were stripped of its teeth.
Hope yours isnt anything like that. Let us know how it looks.
I would say due to you having a act clutch you may have blown the clutch disk..very common for the weak act's to do that..I have done broke 2 of them myself.the puck disk spins the splines right out the hub.
well i'm getting ready to go to work right now, we'll get the car on the lift and see what kind of damage i've done! i'll let you guys know.
well i cracked open the tranny and it was the diff. the spider gears in the diff were pretty much destroyed. now i guess i'll HAVE to put in an LSD diff.. while im at it i'll replace some syncros that were alittle worn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allMotor93Hatch »</TD></TR><TR><TD CLASS="quote">Sorry to hear that. Was there anything else damanged? Good time for LSD
yeah a little chunk of the inner houseing broke off and some other minor stuff so i'm gonna probably end up replacing alot of the stuff inside. if the price gets too high i might just look into getting a type r tranny
</TD></TR></TABLE>yeah a little chunk of the inner houseing broke off and some other minor stuff so i'm gonna probably end up replacing alot of the stuff inside. if the price gets too high i might just look into getting a type r tranny
I own a shop (rollinchassis.com) and i had a lot of customer well a five of them that had blown their b16a tranny as soon as they put an aftermarket clutch on. all of my customer used gsr or type r tranny now. they have no problem with blowning their tranny. well what i tring to said is it cheaper to buy a used gsr tranny then to rebuilt your. you might run it to other problem beside the the spider gear. here are some of the other thing that might being going out that i run into the diff, spine for the clutch.
85_305
Honda Civic (2001 - 2005)
41
Apr 26, 2021 07:43 AM
underpressure02
Apr 23, 2006 06:51 PM
numotive
Dec 30, 2005 04:00 PM
