Replacing ball joints?
Old Sep 27, 2001 | 11:58 AM
sleeperCRX's Avatar
New User
Default Replacing ball joints?
Has anyone done this? I have heard they require a press, and that if you don't have one you're pretty much stuck having a shop do it for you, has anyone had to this and if so what is a reasonable expectation of much I will have to spend? Thanks again.
Old Sep 27, 2001 | 12:36 PM
cjb92's Avatar
Default Re: Replacing ball joints? (sleeperCRX)
I just had mine done and yeah without a press at home you get raped on labor charges. cheapest I found it was $60 for both sides. (ouch)
Old Dec 12, 2001 | 10:25 PM
AGen2integra's Avatar
Default Re: Replacing ball joints? (superflea)
this is a stupid question, but what kind of grease is used in ball joints?? I mean is one type of grease better than anouther?
Old Dec 12, 2001 | 11:52 PM
Mista Bone's Avatar
D Tranny Guru
You can rent a press for free from Autozone.
You can only replace lowers, uppers require whole a-arm be replaced.
Old Dec 13, 2001 | 02:42 AM
REX VT's Avatar
Just use a BIG fat hammer and pound those damn ball-joints out!
Your gonna throw 'm out anyway and you will at max chip some rust of the suspension arms. Greasing in new ball-joints is advisable since you'll want them easier removed next time (f.e. during car maintenance)
Using ball-joint-presses sucks! Trust me: no garage/shop is using them and I sure as hell can't get along with them either!
Old Dec 13, 2001 | 08:12 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Replacing ball joints? (REX VT)
The one you rent from AutoZone is same as what they use at the dealerships.
Once everything is unbolted and out of way, only takes 5 minutes to R&R a ball joint.
PatrickGSR94
Suspension & Brakes
18
May 12, 2010 09:55 AM
MPALUGHI
Aug 28, 2005 01:16 PM
wdskuk
Jul 25, 2004 06:11 AM
zcrxt
Jun 16, 2004 02:32 PM
maxxdout
Jan 5, 2003 12:54 PM
