brake pad squeel?
i just put new pads on my 95 coupe, i have slotted rotors, and i put axxiss pads in. ive done pads before and this squeel never happened. ive checked all the metal clips to hold the pads in and i cant see any of them touching. i had to replace the pad mount piece that the caliper bolts to with a crx dx mount bc the caliper bolt broke on my factory ones. would there be a problem with using this? or anyone have any other ideas? its gettin really annoying and i dont wanna mess up my rotors. but i cant tell wats causing it
never heard of this anti squeel stuff. and i have had these pads before and they didnt squeel. and now they do it like just driving not braking. sounds like somthins rubbing? would the crx part cause a problem?
You need to remove the pads again and smear anti-squeal lubricant on the 'backs' of the plates.
While in there clean your discs with alcohol or brake cleaner and a clean rag/check for foriegn debris that might be causing the noise.
No, it isn't because it's a CRX.
Wear your latex gloves this time, you won't make a mess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneslodx »</TD></TR><TR><TD CLASS="quote"> i had to replace the pad mount piece that the caliper bolts to with a crx dx mount bc the caliper bolt broke on my factory ones. would there be a problem with using this? </TD></TR></TABLE>
Hmm, shouldn't be any problem using that mount if they are the same? Did you 'free' spin the disc once everything was installed to see/hear if everything was quiet and good?
well when i put it on at first it was fine, and the squeel like will stop somtimes, so its definetly i think somthin hittin the rotor, i donno im gunna take it all apart and put it back together and hope i somehow stop it, ill clean the rotors and stuff too. thanx for the help everyone
Toneman14
Sep 23, 2005 08:29 AM
