How To Identify Type R cams
Old Jan 7, 2004 | 06:12 PM
CRVRX's Avatar
Default How To Identify Type R cams
I know this has been covered before but, How do you tell Type R from GSR from SiR cams?
I have a few cams and need to know which is which, Tried the seach.
Thanks.....
Old Jan 7, 2004 | 08:41 PM
Black R's Avatar
25 Year Member
Default Re: How To Identify Type R cams (CRVRX)
..... mic them.
Old Jan 7, 2004 | 09:21 PM
K20DC2R's Avatar
Default Re: How To Identify Type R cams (Black R)
if im correct i belivve the itr cams have 2 rings/slots on the end. i think.
Old Jan 8, 2004 | 04:13 AM
CRVRX's Avatar
Default Re: How To Identify Type R cams (VtecWhore)
Thanks for the replys.
I can mic them , what is the lift of the GSR, Type R and the SiR cams.
Old Jan 8, 2004 | 04:29 AM
visi0n's Avatar
if you look at the end of the cam there is a little 3-4 mm part of the cam that is a perfect circle. the itr and ctr cams will have a slight roundness to one or both the corners of that 3-4mm section.
hard to explain without pictures.
Cummins4LF
Feb 8, 2018 05:34 AM
shcker3
Feb 13, 2009 10:16 PM
blackcrx16
Jun 19, 2007 10:39 AM
djxquizit
Feb 2, 2004 12:58 PM
89civic1.8T
Mar 8, 2003 07:19 PM
