welding 2.0" > 2.5"
Old Jan 7, 2004 | 04:20 PM
s o h c's Avatar
Default welding 2.0" > 2.5"
can you weld 2" piping directly to 2.5" piping directly with a mig welder without any kind of reducer in between?
Old Jan 7, 2004 | 04:46 PM
Padawan's Avatar
Darth ModerVader
Default Re: welding 2.0" > 2.5" (s o h c)
How would you?
Old Jan 7, 2004 | 05:35 PM
s o h c's Avatar
Default Re: welding 2.0" > 2.5" (Padawan)
like this? looks like its just welded but im not sure, thats why im asking
Old Jan 7, 2004 | 06:08 PM
DENCIO's Avatar
I did a 2.25 to 2.50. I was welding from left to right though to fill up the gap..good luck..
Old Jan 7, 2004 | 08:24 PM
LudeyKrus's Avatar
Probably, but why do it ghetto?
But you'd prob. just turn up the wire speed and heat and let'er rip!
Old Jan 7, 2004 | 08:32 PM
IN VTEC's Avatar
A reducer is $2 from the auto parts store.
Old Jan 8, 2004 | 05:03 AM
s o h c's Avatar
Default Re: welding 2.0" > 2.5" (IN VTEC)
but im thinking i wont be able to make the angle with a reducer, it looks like it would hang real low to the ground. thats the only reason why
Old Jan 8, 2004 | 07:01 AM
LudeyKrus's Avatar
Then cut off some piping from the upper smaller pipe. You want that reducer, and you can somewhat angle it a good bit if you mess w/ it. I made the reducer I used on my muffler work w/ some massaging.
Old Jan 8, 2004 | 10:37 AM
rtype11's Avatar
you dont have a pipe flaring tool??? can get one for cheap and its ratchet operated or compressed air attachement - ask the snap on guy when he comes by in the truck. cant guarantee the quality of your welds.
Old Jan 8, 2004 | 12:23 PM
s o h c's Avatar
Default Re: welding 2.0" > 2.5" (rtype11)
i will probably just bring it in to the local exhaust shop and have them flare it to 2.5" for me
Old Jan 8, 2004 | 12:47 PM
cstay's Avatar
if u ran a fiew beeds and build up u could do it its only like a 1/4 inch gap on both sides. but i would suggest getting a flair tool u never know when u could use it.
Old Jan 8, 2004 | 05:10 PM
s o h c's Avatar
Default Re: welding 2.0" > 2.5" (cstay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cstay &raquo;</TD></TR><TR><TD CLASS="quote">if u ran a fiew beeds and build up u could do it its only like a 1/4 inch gap on both sides. but i would suggest getting a flair tool u never know when u could use it.</TD></TR></TABLE>
where do they sell pipe flare tools, and how much are they?
Old Jan 8, 2004 | 05:47 PM
dfoxengr's Avatar
ive always wondered if something like this could actually expand good thickness piping?
ill probably be getting this though kinda primative but heat and hit
both are snapon BTW
Old Jan 8, 2004 | 06:44 PM
s o h c's Avatar
Default Re: welding 2.0" > 2.5" (hybridvteceg)
ya im using 14guage mild steel and i bet its a bitch using one of those things to flare it but i guess ill see
Old Jan 8, 2004 | 06:55 PM
cstay's Avatar
any store like auto zone try maby using a torch to heat up the metal first but be careful not to do it to far because it will crack.
potatostix
Welding / Fabrication
Oct 10, 2009 08:57 AM
civicexowner
Jan 3, 2008 06:48 PM
r3p00c
Mar 8, 2005 10:59 AM
EGPHANTOM
Nov 16, 2004 07:54 AM
zojirushi
Jun 10, 2002 08:39 PM
