DYNO TUNED MY GSR-T... CAR RUNNING HOT... HELP!!!!
Old Jan 7, 2004 | 04:03 PM
oemDC2's Avatar
Default DYNO TUNED MY GSR-T... CAR RUNNING HOT... HELP!!!!
I dyno tuned my gsr turbo at Church Automotive Testing yesterday and shaun church says my car is running hot (coolant temp). What can i do to cool it better? I made 221.3 hp and 162tq @ 6.3 psi , Shaun says if i had a cold air filter and bigger exhaust piping (i used custom 2.5 in exhaust piping that wasnt mandrel bent) I wouldve spooled a lot faster and would probably be at 250ish hp at the psi i was running, i also need a better cooling system.... Can anyone help???
Old Jan 7, 2004 | 04:07 PM
MaxSterling's Avatar
Default Re: DYNO TUNED MY GSR-T... CAR RUNNING HOT... HELP!!!! (oemDC2)
what is your set up, engine internals?, turbo size? manifold? exhaust? fuel management?
Old Jan 7, 2004 | 04:58 PM
oemDC2's Avatar
Default Re: DYNO TUNED MY GSR-T... CAR RUNNING HOT... HELP!!!! (MaxSterling)
revhard kit..stock internals, hondata s200b tuned, 2.5in custom exhaust (not mandrel bent). My dumptube is aim at my oil line and my charge pipe and shaun church says thats is heating my oil and warming up the air in my charge pipe..
Old Jan 7, 2004 | 05:16 PM
oemDC2's Avatar
bump... someone help..
Old Jan 7, 2004 | 05:42 PM
AlphaKennyWun's Avatar
what does your cooling system consist of?
Old Jan 7, 2004 | 05:57 PM
Andres-eh2's Avatar
do you plan on boosting some more lbs.?
Old Jan 7, 2004 | 06:21 PM
oemDC2's Avatar
Default Re: (Andres-eh2)
My cooling system is stock..With the exception of a 10 inch slimfan.. I plan to stay at 6.3 psi for a while
Modified by oemDC2 at 9:35 AM 1/8/2004
Old Jan 7, 2004 | 07:41 PM
oemDC2's Avatar
Default Re: (oemDC2)
ttt
Old Jan 7, 2004 | 07:51 PM
RedTegLS's Avatar
Fluidyne or PWR radiator. PM earl he gots good prices on them.
Old Jan 7, 2004 | 08:06 PM
Reilly's Avatar
My set up is basically the same, but ran 8psi, crept to 9psi at about 7k rpms. At 8psi made 287, 294 with his s2000 cold air set up. Only thing I see different is I have 3" turbo back exhaust(except downpipe), 550's and my turbo is SC34. I had full boost at 4k rpms exactly. Tuned by Church also.
Modified by Reilly at 6:03 AM 1/8/2004
Old Jan 7, 2004 | 08:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oemDC2 &raquo;</TD></TR><TR><TD CLASS="quote">i also need a better cooling system.... Can anyone help???</TD></TR></TABLE>
yeah you can try and get lower degree theromostat at autozone, lower degree fan switch, and/or dual core full radiator. depends on how serious you are bout a few ponys 10-15whp.
about your worries about the down pipe heating up charge pipe. i wouldn't worry about it b/c you are only boosting a minute 6psi. therefore your intercooler is more than enough to cool air.
if you have t3/t04e turbo. it's efficiency is around starts 10-12psi -ish. so you are way under it. if you turned it up to 10psi, i'm sure your hp mark will be around 280-300whp
Old Jan 7, 2004 | 08:34 PM
Mark817teg's Avatar
Little things can also make a difference. When did you change your coolant last? Run a lower temp themostat, try red line water wet or something similar, its a coolant additive.
Clean your engine compartment. Dirt insulates the engine, keeps heat in.
Old Jan 7, 2004 | 08:39 PM
oemDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxSterling &raquo;</TD></TR><TR><TD CLASS="quote">
I have a starion fmic if that would make any difference...
Old Jan 7, 2004 | 09:26 PM
SSR'd's Avatar
turn up the boost
wahahah ...sup rick a.k.a. post *****
Old Jan 7, 2004 | 10:48 PM
oemDC2's Avatar
Default Re: DYNO TUNED MY GSR-T... CAR RUNNING HOT... HELP!!!! (FlyTheCoupe)
sup johnny... Thanks for nothing...You are useless
Modified by oemDC2 at 9:34 AM 1/8/2004
Old Jan 8, 2004 | 12:38 AM
oemDC2's Avatar
I'm worry about my dumptube heating up my charge pipe because it is aimed directly at the charge pipe and my oil feed..
Old Jan 8, 2004 | 12:56 AM
RAWB's Avatar
Did they use a cooling fan while the car was being ran? What was your coolant temp, A/F's at?
Old Jan 8, 2004 | 01:02 AM
Ek00fbp's Avatar
I'm worry about my dumptube heating up my charge pipe because it is aimed directly at the charge pipe and my oil feed..</TD></TR></TABLE>
If it directly at ur charge pipe im sure thats your problem. I have a friend with that exact same problem and his car over heats too. I am boosting alot more than you are with a stock radiator and have had no problems. Just make sure u have enough coolant. You might want to drain it out and put in 30% coolant and 70% water and also add some water wetters. And just to do a couple extra little things get a cooler thermostat like the mugen maybe. But for sure fix that dumptube pointing at ur charge pipe first of all.
Old Jan 8, 2004 | 01:11 AM
oemDC2's Avatar
Default Re: DYNO TUNED MY GSR-T... CAR RUNNING HOT... HELP!!!! (Iloveshannon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Iloveshannon &raquo;</TD></TR><TR><TD CLASS="quote">
If it directly at ur charge pipe im sure thats your problem. I have a friend with that exact same problem and his car over heats too. I am boosting alot more than you are with a stock radiator and have had no problems. Just make sure u have enough coolant. You might want to drain it out and put in 30% coolant and 70% water and also add some water wetters. And just to do a couple extra little things get a cooler thermostat like the mugen maybe. But for sure fix that dumptube pointing at ur charge pipe first of all.</TD></TR></TABLE>
When i was tuning my car, my coolant temp was hot from what shaun church told me... I may be losing some power there but i dont see why my coolant temperature is caused by my dumptube heating up my charge pipe.. My car isnt overheating or anything so thats a good start.. Im planning to fx the dumptube problem though, and also get a new thermostat, maybe a fluidyne..
Old Jan 8, 2004 | 01:54 AM
b00sted93Hatch's Avatar
I say drill some small holes in your thermostat and run some Redline water wetter. Or upgrade to a aftermarket radiator as mentioned before.
rudebwoy
Oct 27, 2007 05:33 AM
Turbo-charged
Feb 18, 2006 02:49 AM
Endoe
Dec 15, 2004 09:41 PM
scatuli
Nov 21, 2003 05:12 AM
