battery dies like crazy
Old Jan 7, 2004 | 03:33 PM
GroundZer0 336's Avatar
Default battery dies like crazy
i dont think its my alternator goin bad, but ill leave my car like 5 hours and the battery will be completely dead. its a new battery like 2 weeks old. what the hell should i do, take off the cable for now when i go somewhere?
Old Jan 7, 2004 | 03:40 PM
TwztdSi's Avatar
Mine used to do that. Somehow one of the cells in my battery had went bad. If you have an Advance Auto Parts or some place similar close by just take it there and they can test it for you. I believe they can test your alternator also.
Old Jan 7, 2004 | 03:44 PM
RCautoworks's Avatar
Default Re: battery dies like crazy (optimus_prime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by optimus_prime &raquo;</TD></TR><TR><TD CLASS="quote"> what the hell should i do, take off the cable for now when i go somewhere?
Search... Since I'm nice here you go. First make sure all your grounds and connections are clean, it sounds like something is draining your battery even when the car is off, to test this put an ammeter in series with the battery, it should read 0, if not start pulling fuses and when it goes to 0, there is your problem.
Took this pic from fouthgenhatch
Old Jan 7, 2004 | 03:49 PM
iplaybass's Avatar
this may sound dumb but, are you sure you didn't leave your dome lights or headlights on?
Could be a bad battery... is there a specific reason why it was just recently replaced?
Old Jan 7, 2004 | 03:52 PM
another_crx's Avatar
Default Re: battery dies like crazy (iplaybass)
my battery was dead as well today when I turned it on. What are those units called that you can check if the battery is being drained. Can I pick em up at Canadian Tire or Autozone?
I dunno if I left anything on or not
Old Jan 7, 2004 | 03:54 PM
Default Re: battery dies like crazy (another_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by another_crx &raquo;</TD></TR><TR><TD CLASS="quote">What are those units called that you can check if the battery is being drained. Can I pick em up at Canadian Tire or Autozone?
I dunno if I left anything on or not</TD></TR></TABLE>
There called a multimeter, you might be able to get a cheap one at autozone.
Old Jan 14, 2004 | 07:04 PM
Default Re: battery dies like crazy (90blackcrx)
ok well this is back from tha dead but...i checked all the fuses, and it seems that my sunroof is pulling power all the time. i pulled the fuse for now ill see if it worked tomorrow when i leave for school.
i think im just gonna rip out my sunroof and get one of the cf plugs for my sunroof.
Old Jan 20, 2004 | 01:15 PM
xtcv's Avatar
do you have an aftermarket headunit? if so are you using an adapter to wire it to the stock setup? on my 00 civic ex i found that the stock cables had a voltage on one of the wires that wasnt being used (alarm to the radio). so i rewired the stereo power along with the amps and now everything works fine.
Old Jan 20, 2004 | 01:29 PM
EF4lyfe's Avatar
whats the website where you got that pic from please?
Old Jan 20, 2004 | 07:10 PM
Default Re: (SIhatch90)
well my battery hasnt died since i pulled my sunroof fuse. so... i dunno whats goin on. haha
Old Jan 20, 2004 | 08:14 PM
manson's Avatar
Default Re: (optimus_prime)
time for a carbon fiber plug.
Old Jan 21, 2004 | 07:29 AM
exactly! i just need like 300 bucks.ha
VTEC_Du_Ma_Mai
Mar 20, 2008 04:48 PM
Integ-boy
Nov 26, 2007 06:12 PM
BigIslandBoi
Aug 22, 2006 09:50 PM
97dc2
Mar 8, 2005 11:31 AM
miksew
10
Jan 10, 2004 04:52 PM
