87 replacement of windows
I just got a 1987 civic that had the windows smashed i need to know how to get the door panel off over the window roller handle. I know i might be stupid but to my knowledge there is no screw in the middle of it to get it off.
thanks for any help
thanks for any help
If you push the door panel in a little bit around the crank, you should see a little clip under the crank. Use a small flat head screwdriver or bend a hook out of stiff wire and pull the clip out. Now the handle should pull right off.
Mentat Ghola
Jan 11, 2003 04:47 PM
IdotheSHOCKER
Aug 15, 2002 03:43 PM
