p28 pinouts
Old Jan 7, 2004 | 03:13 PM
Del_Sol_s's Avatar
Default p28 pinouts/oxygen sensor wire up
can anyone help me figure out how to read the pinouts on a p28, currently trying to wire up my o2 and not sure where d14, a6, d22, and a25/b1 are. if u had a diagram or something it would be great
Modified by jdmvic at 8:07 PM 1/7/2004
Old Jan 7, 2004 | 03:20 PM
aw1234dude's Avatar
Default Re: p28 pinouts (jdmvic)
Old Jan 7, 2004 | 03:21 PM
Del_Sol_s's Avatar
Default Re: p28 pinouts (aw1234dude)
thanx alot
Old Jan 7, 2004 | 05:05 PM
Del_Sol_s's Avatar
another thing, just want to confirm these pin locations for wiring the o2 sensor
white - d14
black - a6
green - d22
black - a25/b1
is this correct??
Old Jan 7, 2004 | 05:23 PM
Del_Sol_s's Avatar
Old Jan 7, 2004 | 05:48 PM
lonefuzzy79's Avatar
Default Re: (jdmvic)
Can you just run the wires to the ECU with out them being part of the engine harness or will that screw things up? Or can you just splice and run two leads to the same place and should you clip any wires that are at those pinouts and replace them with the 02 leads?
Old Jan 7, 2004 | 06:15 PM
Del_Sol_s's Avatar
yea its doable, did it on my civic and it works fine.
jackhunt321
Oct 3, 2006 05:39 PM
MugenHonda
Jun 25, 2005 04:06 PM
5thgen
Oct 13, 2003 05:08 PM
1990hondaHF
11
Aug 21, 2003 09:29 AM
roc
Apr 23, 2003 07:03 PM
