tech question my b16 hatch won't start
ok heres my problem. My alternator was going out so that was a simple fix. I went down tested the alternator and it pulled like 2 volts. So I bought a new one, put it on and the battery light went off. However, while the alternator was failing my car was also starting to lag, and it would sometimes die at lights. It was the same feeling that you get when you run out of gas. However, I have a full tank of chevron 91octane. I was assuming that the stock fuel pump was going out, considering that the car has 14x,xxx miles on it. So I replaced the stock fuel pump with a walbro 255, and I also replaced the fuel filter. I just finished all of this and my car won't even begin to start. Any information or suggestions will be greatly appreciated.
