lower torque mount compatibility?
Old Jan 7, 2004 | 01:09 PM
92civeg's Avatar
Default lower torque mount compatibility?
i have a 92 civic with a 2nd gen b16 swap, and when i got the swap done it didn't come with these two lower torque mounts, and im just wondering, if i could just use the ones from a d-series motor or would they have to be from a b-series
thanks
Old Jan 7, 2004 | 01:20 PM
1.8turbolsvtec's Avatar
Default Re: lower torque mount compatibility? (92civeg)
no you can not usd the civic mounts you need 94 and up gsr or ls and that will work the only one you can used off the civic is upper trans mount have fun with it
Old Jan 7, 2004 | 01:24 PM
92civeg's Avatar
Default Re: lower torque mount compatibility? (1.8turbolsvtec)
is the "upper trans mount" the one labeled right front mount?
i only need the ones labeled right front mount and left front mount
Old Jan 7, 2004 | 01:36 PM
no that is trassmission mount .you need right front and left front mounts. need to be off 94 up gsr or ls i have doen swaps alot if you have any more ? im me lsvtec1975
Old Jan 7, 2004 | 02:27 PM
92civeg's Avatar
i need #'s 11,12,13 and all hardware surrounding those
Modified by 92civeg at 6:38 PM 1/7/2004
Old Jan 7, 2004 | 03:38 PM
92civeg's Avatar
someone has to know
Old Jan 7, 2004 | 05:05 PM
92civeg's Avatar
ttt
Old Jan 8, 2004 | 02:32 AM
that is right 11 12 13 1 16 17 and all the hardware
Old Jan 8, 2004 | 03:21 AM
HYBRID_H@TCH's Avatar
I have the #1 in that diagram..if you need it let me know..its from a 95 gsr.
Old Jan 8, 2004 | 10:23 AM
doublejz's Avatar
Default Re: lower torque mount compatibility? (99Hybrid_Hatch)
i just put a b16 2nd gen in a 93 eg and i used all the mounts from the d16z6 except for the rear, and passenger side (auto to man conversion) and everything fits fine.
Old Jan 8, 2004 | 11:00 AM
DavidR's Avatar
Default Re: lower torque mount compatibility? (doublejz)
I believe the rubber mounts are the same.
Old Jan 8, 2004 | 02:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">i just put a b16 2nd gen in a 93 eg and i used all the mounts from the d16z6 except for the rear, and passenger side (auto to man conversion) and everything fits fine.</TD></TR></TABLE> the brackets are not the same as a z6
Old Jan 8, 2004 | 07:19 PM
92civeg's Avatar
so do i need them from an integra or can i use the ones from a civic?
Old Jan 9, 2004 | 03:45 AM
YES GSR OR LS
Old Jan 20, 2004 | 07:43 PM
NAB16AEK's Avatar
I also need those mounts if anyone has them.
dizzled15
11
Feb 2, 2015 03:49 PM
journeyquest
Mar 29, 2013 06:35 AM
sloweredcivic
May 15, 2005 09:01 PM
crx8psi
Jan 19, 2004 08:29 PM
b20ek
Apr 30, 2003 10:48 PM
