im confused..just got back from autozone
i went to orilleys yesterday to see if i could get a passanger upper ball joint, but no luck..ofcourse i could only get the whole UCA, but it was only $102 so thats better than honda. Well today i decided to be a "smart shopper" and checked out autozones price..they actually showed balljoint in there computer system for $84.99, either way im gettin a better price so placed the order, but do you think ima get an actual balljoint or the whole UCA? part #334849.
I'd rather not have to replace my whole UCA cause it was a pain in the *** getting my ingalls to fit in the UCA arms and also i dont feel like grinding down the edge off of the UCA (again) to fit in the fender
Modified by X-Static at 7:11 PM 1/7/2004
Good luck putting the upper ball joint into the uca, from what I hear they are pressed together....usually they are only sold as one piece.
Hope you get 1 piece.
Not all Upper A arms have clips.. some are welded in depends on year later models have clips.
a hammer and a vise if used correct can be used in liu of a press..
you can buy adjustable upper ball joints from spc and use those instead of the ingals type camber kit..just another option
for those of you that think they cant be removed...they can, honda just likes bein a punk about it. 90-91s arent welded together. if i didnt have the ingalls ancor bolts i would go ahead and get the adjustable ball joints but ive already got my camber situation under control. If it is just the ball joint i will rent a ball joint press from autozone, whats the big deal?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brianbrannon »</TD></TR><TR><TD CLASS="quote">upper ball joint is held on by a snap ring. You should be able to find just the ball joint for 30 bucks or less. I got a whole arm for 50</TD></TR></TABLE>
where can you find the balljoints for $30??..also where did you find the arm for $50??
carl_aka_carlos
Feb 9, 2003 10:14 PM
2000Accord5sp
Jan 30, 2003 04:03 AM
