Cannot start car after vandals broke in...
Old Jan 7, 2004 | 10:52 AM
Seedc2's Avatar
Default Cannot start car after vandals broke in...
Other than those loose wires(I believe they are from my alarm) I don't see anything else that was disconnected..
I cannot start the car.. I can only hear the starter attempting to start the motor to no avail...
I disconnected the battery in hopes to deactivate my alarms kill switch if it was activated to begin with. Still nothing..
I need to get my car to a shop asap but I cannot get the car to start..
Modified by kendogg at 3:20 PM 1/7/2004
Old Jan 7, 2004 | 11:49 AM
FF-Greg's Avatar
Default Re: Cannot start car after vandals broke in... (kendogg)
damn that sux man, *** thieves hope u get ur car running.
Old Jan 7, 2004 | 11:51 AM
Grease Monkey's Avatar
where is the alarm? If its just wires left take them off and solder the old wires back. Car should start.
Old Jan 7, 2004 | 12:22 PM
m R g S r's Avatar
Default Re: Cannot start car after vandals broke in... (Grease Monkey)
Maybe they blew a fuse. Check the ECU fuse, maybe it's not giving the engine any fuel or spark. Also can you hear the fuel pump priming? If not, then check the fuses.
Is that an R>? What did they get out of it?
Old Jan 7, 2004 | 12:24 PM
Default Re: Cannot start car after vandals broke in... (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Maybe they blew a fuse. Check the ECU fuse, maybe it's not giving the engine any fuel or spark. Also can you hear the fuel pump priming? If not, then check the fuses.
Is that an R&gt;? What did they get out of it?</TD></TR></TABLE>
oh yea... so what he says as well. They may have blown a fuse.
theycallmedalgo
Aug 31, 2007 03:16 AM
SlammedDC2
Nov 2, 2005 01:44 PM
TheIntegraGuy
Aug 18, 2005 05:57 PM
blks2k3
Apr 5, 2005 05:45 PM
chasingamy
28
Jul 18, 2004 10:18 PM
