Extending O2 wire help!!! please
Old Sep 27, 2001 | 09:34 AM
ZUL8R's Avatar
Default Extending O2 wire help!!! please
What do i need to do and where can i get the wire.. im doing this so i can install header and cat on my civic.. need to extend the wire thanks for the help!!!
Old Sep 27, 2001 | 10:49 AM
rainforest's Avatar
Default Re: Extending O2 wire help!!! please (shane89z24)
why do you need to do this? You can use any wire. get it at home depot. and just cut the wire and extend it, clip it then put electrical tape over it.
Old Sep 27, 2001 | 12:37 PM
riot's Avatar
didn't I reply to this already? Use cat 5 network cable.
-ryan
Old Sep 27, 2001 | 12:41 PM
keithv's Avatar
Default Re: Extending O2 wire help!!! please (rainforest)
I would definitely solder the wires together, especially if they are exposed to the elements...
Old Sep 28, 2001 | 07:01 PM
racer4200's Avatar
New User
Default Re: Extending O2 wire help!!! please (breaka_1_9)
Yup solder them, definately. I extended mine. I made them way tooooo long. Its worked fine for over a year.
Old Sep 30, 2001 | 02:00 AM
dj_fixx's Avatar
New User
Solder and heat shrink(radio shack) Best
do not use electrical tape, the heat will cause the adheasive to fail
butt connectors work also, use real crimpers
but the connector eventually rust(oxidize)
Old Sep 30, 2001 | 04:40 AM
92CivicSiR's Avatar
New User
Default Re: Extending O2 wire help!!! please (dj_fixx)
Listen to dj_fixx, he is telling you the correct way to do this. Solder and heat shrink, any person who jsut cuts wires under the heed and then tapes them is asking for his motor to blow up.
97spooncivic
Mar 18, 2006 12:15 AM
Civicse
Feb 3, 2006 01:01 PM
bigedx
Apr 28, 2004 09:09 PM
sherman
Mar 17, 2003 06:04 PM
ZUL8R
Sep 27, 2001 10:24 AM
