Crx Mini-Me wont rev pass 3500rpm
Old Jan 7, 2004 | 07:43 AM
rainmanef's Avatar
Default Crx Mini-Me wont rev pass 3500rpm
I have a 1990 CRX si. I put a mini-me in there but for some reason the motor wont rev past 3500rpm. Anyone know how to fix this or had the same problem?
In addtion to that problem it idle all funny. it sounds like a v8 then shuts off........help
Old Jan 7, 2004 | 07:45 AM
91civicDXdude's Avatar
your cam timing is off
Old Jan 7, 2004 | 11:21 AM
RuthlessEF-9's Avatar
Default Re: (91civicDXdude)
you could also check your dizzy inside try looking at your cap and rotor
Old Jan 7, 2004 | 11:26 AM
crxgator's Avatar
Default Re: Crx Mini-Me wont rev pass 3500rpm (babyboyeg6)
we need a little more info, like did you run it obd1, what ecu are you using, what codes are you throwing if any...
Old Jan 7, 2004 | 03:17 PM
rainmanef's Avatar
Default Re: Crx Mini-Me wont rev pass 3500rpm (crxgator)
I'm using a obd0 pr3 ecu. I get the crank angle sensor code. Timing cant be off I corrected that perfectly. Could the crank angle sensor be the prob?
Old Jan 7, 2004 | 03:34 PM
BMacls's Avatar
im haveing the same problem but i cant rev pass 5500rpm and i have tried the pr3 and the stock si ecu. and im useing the the make on the underdive pull with the two lines not the one line. and then i have tried adjusting my cam gear. now it adjusted +3. didnt you remove the oil jet. i did and i thinking thats the problem. but if you get it fix help me out
Old Jan 7, 2004 | 04:40 PM
crxgator's Avatar
try a different distributor...
i take it you are using a Y8 head with an A6 distributor correct?
Old Jan 7, 2004 | 06:09 PM
rainmanef's Avatar
yup buy a z6 head on the a6 bottom. so try changing dizzy?
Old Jan 7, 2004 | 06:11 PM
crxgator's Avatar
um maybe thats your problem...
Old Jan 7, 2004 | 08:28 PM
Ryan C's Avatar
crank angle sensor is in the distributor. when my code went the car ran like ****. try an SI dizzy thats new or on a running car. It sounds like thats ur problem.
Old Jan 7, 2004 | 08:40 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (Ryan C)
um.... any codes?
civhatch90
27
Nov 29, 2006 09:05 AM
crx_soldier
May 2, 2005 01:16 PM
South Bay Surfer
Feb 23, 2004 10:01 AM
msrrex
Nov 2, 2003 10:14 AM
brownshigh
Nov 12, 2002 07:09 AM
