are u using tube or pipe for ur custom 3" DP and exhaust??!
Old Jan 7, 2004 | 07:40 AM
Chillinit's Avatar
Default are u using tube or pipe for ur custom 3" DP and exhaust??!
Gonna make my own Dp and exhaust...wondering if u guys are using tube or pipe....if tube..what gauge? if pipe..what sch?..thanks!
Old Jan 7, 2004 | 08:33 AM
Chillinit's Avatar
Default Re: are u using tube or pipe for ur custom 3" DP and exhaust??! (Chillinit)
Old Jan 7, 2004 | 08:49 AM
RedTegLS's Avatar
Hmmm this is interesting.....tube....what kind of tube? Rubber tube? Plastic tube? Copper tube? A little more info would be awesome!
Old Jan 7, 2004 | 09:10 AM
Chillinit's Avatar
Default Re: are u using tube or pipe for ur custom 3" DP and exhaust??! (RedTegLS)
no man...stainless!! stainless steel can be specified in different forms...tube or pipe
tube = gauge!
pipe = schedule!
rubber tube? plastic tube?
I want to use tube but I don't know if that would be too thin? 14 gauge? anyone?
Old Jan 7, 2004 | 09:21 AM
B18Flip's Avatar
16 guage should be fine, 14 will work too but it may be overkill for a downpipe.
16 ga. 304L & 316L pipes
Old Jan 7, 2004 | 09:49 AM
Chillinit's Avatar
Default Re: are u using tube or pipe for ur custom 3" DP and exhaust??! (B18Flip)
thks flip....does anyone know what thermal uses..16ga?
Old Jan 12, 2004 | 09:02 AM
KTeller8's Avatar
we use 16 gauge:
we sell bends to tinker, mike a at 10-94 as well as many other people:
Old Jan 12, 2004 | 09:49 AM
buck02's Avatar
is that a 3inch or 2.5 downpipe on that inlinepro header and who made it i like alot <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip &raquo;</TD></TR><TR><TD CLASS="quote">16 guage should be fine, 14 will work too but it may be overkill for a downpipe.
Old Jan 12, 2004 | 09:50 AM
aka010010
Guest
Posts: n/a
no 2 big and 2 loud
Old Jan 12, 2004 | 09:51 AM
B18Flip's Avatar
Default Re: are u using tube or pipe for ur custom 3" DP and exhaust??! (h22civic2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22civic2 &raquo;</TD></TR><TR><TD CLASS="quote">is that a 3inch or 2.5 downpipe on that inlinepro header and who made it i like alot </TD></TR></TABLE>
thanks man, i made it for another HT member...its an inlinepro stainless mani, turbosmart WG and its a 2.5" flared to 3" downpipe...flared after the a/c compressor
Modified by B18Flip at 2:03 PM 1/12/2004
Old Jan 12, 2004 | 02:52 PM
buck02's Avatar
hit me a email on how much you charge me to build the exact smae one i have the same set up i need it 2.5 to flare to 3 inch let emknow please emial me blemoine02@aol.com
Old Jan 12, 2004 | 04:07 PM
B18Flip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22civic2 &raquo;</TD></TR><TR><TD CLASS="quote">hit me a email on how much you charge me to build the exact smae one i have the same set up i need it 2.5 to flare to 3 inch let emknow please emial me blemoine02@aol.com
Sent you an
Old Jan 12, 2004 | 06:40 PM
This One's Avatar
**** runs through pipe
Tubing is measured from OD
Piping is measured ID
Old Jan 12, 2004 | 06:50 PM
redboost10's Avatar
Default Re: are u using tube or pipe for ur custom 3" DP and exhaust??! (tHIS oNE)
i got my 3" id pipe from napa, got like 10' straight, 2 90 bends, and 2 45 bends for around $145. took stock off and started welding 3" to match it.
Old Jan 12, 2004 | 10:26 PM
KTeller8's Avatar
i got the bends here.. just let me know!!
Old Jan 13, 2004 | 05:35 AM
Phoenix GSR's Avatar
pipe is WAY too heavy for an exhaust... a 3" schedule 40 pipe 6 ft long weighs 150 lbs... tube is definately they way to go.. for exhausts I think the thinner the better (to keep weight down) and it is not load bearing so it doesnt have to be too strong
Old Jan 13, 2004 | 06:34 AM
KTeller8's Avatar
Default Re: are u using tube or pipe for ur custom 3" DP and exhaust??! (Phoenix GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phoenix GSR &raquo;</TD></TR><TR><TD CLASS="quote">pipe is WAY too heavy for an exhaust... a 3" schedule 40 pipe 6 ft long weighs 150 lbs... tube is definately they way to go.. for exhausts I think the thinner the better (to keep weight down) and it is not load bearing so it doesnt have to be too strong</TD></TR></TABLE>
not thinner the better, remember you need it also strong enough to not rust/rott or crap out on you in a year:
fo ic piping and what not.. kinda same thing, to thin would allow a bit of heat to soak in:
Old Jan 13, 2004 | 06:44 AM
PM-Performance's Avatar
Default Re: are u using tube or pipe for ur custom 3" DP and exhaust??! (KTeller8)
i got all my bends for IC piping and my 3inch Ex pipe from Kteller. Very good stuff and great person to deal with
Old Jan 13, 2004 | 07:52 AM
DIRep972's Avatar
Smarter than you
don't go thinner then 16gauge on the downpipe because its very hot there and very prone to scraping the ground. from the oil pan back im going w/ 18gauge to save weight.... It will save about 30% which adds up to a lil under 7-8 lbs wieght savings for stainless steel. every little bit counts
sharkytm
Nov 17, 2006 07:46 PM
sharkytm
Northeast (Sales)
Nov 16, 2006 06:03 PM
FURACERMAN
Welding / Fabrication
Jan 6, 2006 06:32 PM
RACEPAK
16
Aug 19, 2004 04:36 PM
filetofit
Nov 21, 2002 04:53 PM
